Old 06-29-2017, 01:23 PM   #1
RatBrawd
RatBrawd's Avatar
Common Quirks As A Classic Chevy Owner?
Hi guys! I've noticed an issue on more than one of the Chevy's we have. When turning the key to RUN position to start on the 62, 67 C-10s and 57 Bel Air, it makes 1 tick/tap noise but will not turn over. It almost sounds like something is tapping something every time you tap it to Run. It's random, and sometimes if you have the patience to keep trying, it will finally seem to engage and turn over. All 3 are vehicles are AT Column shift, and the BF has a theory that if you slam the shifter through all gears and back into Park/Neutral, it makes it start. I haven't seen this happen regularly to make me think this is where the issue somehow lies. Have any of you experienced this? What was the solution for you? Also, what other quirks do we have to work through as owners of these Cool Old Classics?
RatBrawd is offline   Reply With Quote
Old 06-29-2017, 02:58 PM   #2
Nanook
Nanook's Avatar
Re: Common Quirks As A Classic Chevy Owner?
That is typical of a starter/starter circuit problem.
Things to check...battery cable connections, starter solenoid, battery condition, etc.
Nanook is offline   Reply With Quote
Old 06-29-2017, 03:21 PM   #3
TopFuel1966
TopFuel1966's Avatar
If after you have checked the condition of the battery and the cables and their connections for corrosion and tightness you still have issues, Google "GM starter heat soak".
TopFuel1966 is offline   Reply With Quote
Old 06-29-2017, 03:39 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
This link is the FAQ page, in it you will find a bunch of threads:
http://67-72chevytrucks.com/vboard/s...d.php?t=646002
Starting issues related to heat soaking of the starter
Old 06-29-2017, 05:31 PM   #5
RatBrawd
RatBrawd's Avatar
So after reading this Index,(which I apologize for not referring to first) I'm gathering the issue is in an overheated starter solenoid. As far as starter heat shields or starter solenoid heat shields, do they work to keep heat out or do they hold the heat in? I recently sold a customer a heat shield and wondered about it; Or, am I missing the point all together and the "heat soaking" is actually internal to the solenoid? I'm sorry for sounding Dumb. I just want to learn and understand.
Old 06-30-2017, 09:38 AM   #6
The Rocknrod
Moderator
Keep heat away from the starter solenoid. Also grounds can be a problem, not clean connections etc.
Old 06-30-2017, 10:08 AM   #7
gmcbigbl
gmcbigbl's Avatar
All column automatics, first thing I'd check is the neutral safety switch not properly aligned
gmcbigbl is offline   Reply With Quote
