06-29-2017, 04:21 PM | #1 |
1951 1/2 ton rear mount fuel tank
Howdy everyone, new to the forum. I just got a 1951 GMC half ton. Pretty decent shape, at least its a good solid starting point. I just installed a limited slip rear end out of a 99 explorer with rear disk brakes. Now I want to move the fuel tank out back. I keep finding tanks where you have to cut a filler hole through the floor of the bed. Seems counter intuitive to me....its a truck bed, stuff goes in it. Does anyone have suggestions for a tank with a side filler? I saw a pick of one that has the filler come out the side of the bed right next to the brake light. That's sort of what I've got in mind. What are all of you using?
06-29-2017, 07:06 PM | #2 |
Post Whore
Re: 1951 1/2 ton rear mount fuel tank
Check out boyds welding side fill tanks..
06-29-2017, 08:34 PM | #3 |
47 48 truck tank would work too. Goes through the bed side behind the cab on the passenger side, underneath the bed wood
06-30-2017, 08:39 PM | #4 |
Go though the build threads. Several guys have put rear mounted gas tanks in their trucks in them an have good photos showing the install. Some adapt an oem tank and some use a custom tank.
06-30-2017, 08:47 PM | #5 |
Here is one Iowaboynca showed in his build http://67-72chevytrucks.com/vboard/s...=663622&page=4
That "should" take you to page 4 of the build. Scroll down. He used a Tanks Inc. custom tank on his.
07-01-2017, 03:12 AM | #6 |
Hey 51Hammer, welcome to the site!
Thanks mr48chev for the reference! Back to the question at hand, I got the idea from Advanced Design and DWCSR's builds. See links below. http://67-72chevytrucks.com/vboard/s...627134&page=41 http://67-72chevytrucks.com/vboard/s...569491&page=13 To be honest, DWCSR did this first and we just follow. He's going through to the fender. I know there's a couple of other builds that went up through the fender but for the life of me I can remember who. try a search on "camaro" or "mustang" tank. That should help. |
07-01-2017, 09:55 AM | #7 |
I pulled a few pics from my build to show how I did mine. I had a custom tank, but any tank with the fill going to the side can use this same type of set up.
Mine was set up to have it go thru the drivers fender. I use a Hagen gas fill kit that I welded to the fender. Then I use exhaust tubing for the bends, and gas approved rubbers to tie it all together. Pic 1 the tank Pic 2 Hagen kit installed in fender Pic 3 Back side of fender show part of the system. Pic 4 The second piece that tied the fender elbow and tank together. Hope this may give you some ideal to get yours done...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
07-01-2017, 01:24 PM | #8 |
Post Whore
Oldman..I've been eyeing that hagan gas fill setup..how do you like it and how was fitment to the fnder curve?
07-01-2017, 11:20 PM | #9 |
I like it real well, been using it for 13 yrs. Fitment was good, I aligned it from the backside of fender, so that the top of the gas fill, door closed, layed good on the fender, mark it and cut the hole, layed unit on top of the fender and welded it in place. Hope that's clear, if not let me know...Jim
07-02-2017, 08:30 AM | #10 | |
Tags |
51 fuel tank |
