70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Alternator Bolt
I removed my alternator and took it for a redo. On the curved adjustable bracket for the alternator the bolt that does throught to the alternator doesn't look right to me. As you can see in the attached pic there is just abolt there no washer or anything else. Does anyone have an original alternator with the original factory bolt in it so I can see the proper way to secure the alternator. My bracket was broken and I have an original to replace it with.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
![]() Join Date: Dec 2013
Re: Alternator Bolt
There should be a flat washer on the bolt .
Old member
![]() X2! Flat washer always on the head. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Jul 2015
Re: Alternator Bolt
Ace hardware has hardened washers. Everyone I had on there used to bend into a cup. The threaded hole in that alt always will give way after a while due to tightening. Its a die cast assembly and it is not very suitable for the application.
I removed that junk, bored out the threaded hole on the alt then replaced all with hardened nut, washers, and bolt. No issues now. |
#5 | |
Re: Alternator Bolt
Re: Alternator Bolt
bolt with a flat washer and the bolt should be long enough to go all the way through and catch all the threads on the alternator or it will strip out
