Old 06-29-2017, 10:37 PM   #1
OhCookie
OhCookie's Avatar
Lug nuts
I need to replace a lug nut, or get all new ones, and wanted to find out if the ones currently on the wheels are correct. It's for a 1970 C20. My mechanic had to replace one while working on the brakes so now one wheel looks mismatched. Any guidance would be appreciated.
OhCookie is offline   Reply With Quote
Old 06-29-2017, 10:53 PM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: Lug nuts
You are just missing one of the plastic lug nuts for those 1988-up wheels and caps. I just hope he used a 9/16 lug nut. These take a special lug nut that you can thread the plastic caps over. The 1988- trucks are metric sized vs. our old trucks 9/16-18 on 3/4 tons-1 tons.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 06-29-2017, 11:31 PM   #3
OhCookie
OhCookie's Avatar
Re: Lug nuts
Good to know and I hope he did too.
Old 06-30-2017, 12:03 AM   #4
FirstOwner69
FirstOwner69's Avatar
Unhappy Re: Lug nuts
Are there threads on the outside of the outlier lug nut? If so, just the plastic cap is missing. If there are no threads on the outside you'll need a dual thread (sometimes called conversion) lug nut as well as the plastic cap. The plastic cap screws onto the lug nut. Both should be available on eBay. If your truck has not been converted to front disc brakes, all your wheel studs are probably still 1/2". If converted, at least the fronts may be 9/16".
FirstOwner69 is offline   Reply With Quote
Old 06-30-2017, 12:06 AM   #5
Classic Bowties
Always on the hunt...
Re: Lug nuts
OhCookie says that he is working on a 1970 C20, so if original yet his truck has 1/2"-20 studs/nuts. The larger 9/16"-18 stud/nuts came in 71 on the C/K-20's with the introduction of front disc brakes. Mel
Classic Bowties is online now   Reply With Quote
Old 06-30-2017, 10:45 AM   #6
OhCookie
OhCookie's Avatar
Re: Lug nuts
My truck is original and still has the drum brakes, recently updated but still drum. BTW, I'm a she and not a he.
Thank you for the great information, now I have a much better idea of what is on my truck.
