Old 10-23-2003, 10:02 PM   #1
Nelson
Fram Oil Filter
Which Fram oil filter works with the 350? Is it the Ph5, or Ph 13?
I know dumb question, but I heard that they don't make one of the 2 oil filters anymore. Thanks
Nelson
1970 C10 350 Auto.
A/C not Working
Nelson is offline   Reply With Quote
Old 10-23-2003, 10:08 PM   #2
kroodawg
Cant help with the fram but know that the ac delco is a PF35
1968 SWB CST
kroodawg is offline   Reply With Quote
Old 10-23-2003, 10:12 PM   #3
jorgensensc
jorgensensc's Avatar
I use the ph13 in my 350
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 10-23-2003, 11:29 PM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
I quit using Fram filters after reading this. Switched to Wix.
http://minimopar.net/oilfilterstudy.html
http://minimopar.net/oilfilters.html
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 10-23-2003, 11:42 PM   #5
lukecp
Formerly yellow72custom
lukecp's Avatar
I don't use Fram filters either...i have cut one open and they don't have alot of material on the inside.
I use a Wix 51061 for my 350 (has an anti drainback valve too). Costs about $5.50 but is worth every penny IMO
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 10-23-2003, 11:50 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I always used PH13, untill i too cut one up. I use NAPA filters, but that's becouse I get them free at work. (they are made by WIX)
Old 10-23-2003, 11:58 PM   #7
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
use a wix man - i saw a cut-away of a bunch of fliters & wix was the best - thicker metal & better guts. They're more coin but thats all I use.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 10-24-2003, 12:15 AM   #8
ZOOMY
FRAM
I used Fram for years. They used to be good. Now all they have in mind is corporate profits & make them as cheap as possible. I've also switched to NAPA......Zoomy
ZOOMY is offline   Reply With Quote
Old 10-24-2003, 12:21 AM   #9
Phillip Johnson
Phillip Johnson's Avatar
Wix, Hastings, Napa are about the only good filters on the market. Fram is like on the bottom with AC Delco one step up from that. Its called you get what you pay for. Fram $2.49 at Wallmart or you can pay $5 or $6 for a real filter. Kinda reminds me of when I bought a helmet for my Polaris. The guys said you buy a $20 helmet if you have a $20 head. the same goes for filters. Its protecting the life of the motor. All I can add is DON"T use Valvoilne Maxlife! Just my 4.5 cents worth.
Phillip Johnson is offline   Reply With Quote
Old 10-24-2003, 12:22 AM   #10
jorgensensc
WOW!!! With this new info I will definately be switching to a Wix filter. Thanks for setting me on the right path!!! Funny how this thread changed from a 'which part number' to a you need to change to a different filter. Thanks again for the great info!!!
Shawn
Old 10-24-2003, 04:13 AM   #11
68LSS1
68LSS1's Avatar
If you use NAPA filters only use the gold. They are rated real well (flow versus filtration). K & N are the tops and Mobile 1 is a good filter also.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 10-24-2003, 04:36 AM   #12
BadAssChevy502
Yeh It's Fast
BadAssChevy502's Avatar
Thumbs up PF35
I always use the ac delco PF35 works fine for me
(I'm sorry if the spelling isn't correct,i'm trying the best I can )
1972 C20 3/4 Pickup Fleetside 502ci Th400
Click here to view pictures of my truck
1971 C20 3/4 Pickup Fleetside 350ci 3speed manual gearbox
"IF IT AIN'T BROKE DON'T TRY TO FIX IT"
Zwijndrecht,
The Netherlands
Europe
BadAssChevy502 is offline   Reply With Quote
Old 10-24-2003, 10:04 AM   #13
Mixup
By the way they don't make the PH 13 anymore it's now PH 5.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 10-24-2003, 11:11 AM   #14
Bowtiefreak
Bowtiefreak's Avatar
Yep, Fram are junk. They spend more on advertising than anyone else and then end up with the worst filter on the market.
WIX,Mobil 1,NAPA,Purolator and K&N are about the only way to go.
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
Old 10-24-2003, 11:21 AM   #15
jorgensensc
I just bought a PH13 2 weeks ago? when did they quit making them? Not that I really care since I won't be using them again
Old 10-24-2003, 05:35 PM   #16
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Thge local Kragens has PH13, I just bought one. Thinking on taking it back now
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 10-24-2003, 07:10 PM   #17
cableguy0
there are only 3 manufacturers that make oil filters one is fram the other hastings and the other purolator other then that one of those 3 companies make them. i use purolators myself
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-24-2003, 07:22 PM   #18
Denny
Denny's Avatar
I have been using Mobil1 oil filters. I agree you get what ya pay for. I don't skimp on oil filters or air filters or oil breathers.
1969 Chevy C10. Dakota Digital Gauges, 383 Votex Engine, MSD 8361 Distributor, MSD 6A Unit, Demon Carb, Phoenix Transmission 4L80E trans, 3:73 Posi Rear End
Early Classics 6 Lug Disc Brakes and Spindles
All Stainless Lines
Denny is offline   Reply With Quote
Old 10-24-2003, 08:17 PM   #19
low 84
low 84's Avatar
i use the napa golds also. i think the part number is 1061. but if you give them the fram part number you use they can cross referance it for you.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 10-24-2003, 08:48 PM   #20
EdB
I use a bypass and a Fram filter. After reading these posts,
I believe I will switch from the Fram.
EdB
EdB is offline   Reply With Quote
Old 10-24-2003, 09:10 PM   #21
krue
Designated A-hole!
krue's Avatar
Since I joined the board I have quit using Fram myself. Just another gold nugget of knowledge gained here!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 10-24-2003, 09:24 PM   #22
68LSS1
68LSS1's Avatar
Not entirely correct. And what makes it hard is some brands change the manufacture that makes their filters.
Honeywell (merged with Allied Signal and owns Bendix and others) makes Fram, Deutch, Luberfiner, Toyota OEM and did make Quaker State (for many years).
Avin Meritor makes Purolator Premium Plus, PureOne, Ford OEM, V1, and now Quaker State among others.
DANA makes filters for WIX and makes the NAPA Gold (NAPA Silver filters are made buy cheapest bidder and manufacturer has varied so stay away from these--see my post above).
Clarcor owns Baldwin and Hastings and also makes Amsoil's filters.
Champion Labs makes Mobil 1, K & N, Supetech, Bosch Premium, STP, Ultra Guard Gold, and AC Delco Duraguard. Keep in mind even if different brands are made in the same factory by the same company, quality is different between them as Champion Labs shows having some of the best and some not.
Additionally DANA makes MOPAR/Autopar, AC Delco and Ford For Canada.
Confused yet?
'68 Short Step
Old 10-24-2003, 10:22 PM   #23
Nelson
I also remember as a kid the old Kralinator Filter factory that was a few blocks away from where I lived. It's now Dana!
Nelson
1970 C10 350 Auto.
A/C not Working
Old 10-24-2003, 10:42 PM   #24
72skytop
72skytop's Avatar
I have never unscrewed a Delco PF-35 off an engine because the filter failed. Just like I have never seen a round or worn out Firestone tire as the belts always break before they wear out, but that is another hot topic we can save for a thread all its own!
Kevin Korff
Evansville, IN 47711
1997 Silverado 3500 LWB Vortec 454, headers 4.11 posi. Victory Red WOW!
1976 Oldsmobile 98 Regency four door 42,000 miles original paint. This is still a car!
1990 Oldsmobile 98 Touring Sedan 34,000 miles
1983 Hurst/Olds 30,000 actual miles
2013 Ford Taurus SHO
1972 Hurst/Olds-a work with no progress
1972 Oldsmobile 442 Convertible 455
72skytop is offline   Reply With Quote
Old 10-25-2003, 12:08 AM   #25
68LSS1
68LSS1's Avatar
I don't believe that the bigger issue is the filter failing. And how do you know the filter wasn't bypassing? How do you know how well it was working (filtering)? More importantly how good of filter is it? Flow versus filtration are the keys here. Filters are just like intake manifolds or heads. Some suck, some are good and some are outstanding. I, like many assumed Fram was a top of the line filter. Never used anything but Fram and Castrol Syntec. Then someone told me otherwise which led to research which led to Fram sucks and Castrol Syntec is not a synthetic (except for the price). Everyone will have their personal tastes and there is more than one good filter out there and more than one good oil. It just seems like most don't put the same thought into the oil and filter brand like they do with a carburetor purchase. Sort of similar to the synthetic versus non synthetic arguement. Why wouldn't you want a few easy horsepower and a average of 9 degrees less operating temp for your engine? For a lot of people the cost is the deciding factor for not using synthetic. But by having a few oil analysis done most can extend the oil change interval to make up for the cost.
OK off my soap box now.
'68 Short Step
