Old 07-01-2017, 07:48 PM   #1
BrightonK5
Body mounts before rockers and floor panels
Should the body mounts be replaced prior to replacing floors and rockers? I cut out the rusty metal already and I'm wondering if I should replace the mounts before the new metal. Thanks,
BrightonK5 is offline   Reply With Quote
Old 07-01-2017, 07:59 PM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Body mounts before rockers and floor panels
It's a good idea to do so. Mine were replaced with the top bolted on as well.
Old 07-01-2017, 09:15 PM   #3
toomany2yz
I'm putting new mounts on when the body goes back on to the frame. Get everything straight for the most part, then go about replacing metal. I need to do both rockers, drivers floor, a-pillar and rocker boxes. Top will also stay on along with the door braces I welded in.
toomany2yz is offline   Reply With Quote
Old 07-01-2017, 09:42 PM   #4
Mountain man 71
I just got my new body mounts in the mail Friday. I am going to install them before I replace rockers and get all the panels lined up.
Mountain man 71 is offline   Reply With Quote
Old 07-02-2017, 02:20 PM   #5
notsolo
notsolo's Avatar
Body mounts and Blazer door alignment is critical.
notsolo is offline   Reply With Quote
Old 07-02-2017, 10:18 PM   #6
BrightonK5
Thanks guys, I appreciate your replies and those diagrams are a huge help...
Old 07-03-2017, 10:04 PM   #7
Mountain man 71
I got to work on my blazer today. I got the top bolted on then got all the bolts out of the left side had to pull the radiator off to get the bolt out of that mount. Going try to get them done in a couple days.
