Old 07-02-2017, 06:31 PM   #1
Captmatt
I6 PCV question
This is the PCV valve on my 64 I6 motor. It doesn't seem correct to me and I've never seem one like it before. There is no valve inside. Any thoughts ??
Captmatt is offline   Reply With Quote
Old 07-02-2017, 06:32 PM   #2
Captmatt
Re: I6 PCV question
Pic 2
Old 07-03-2017, 01:31 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: I6 PCV question
The end of that looks like a speedometer gear housing.
Old 07-03-2017, 02:23 PM   #4
CousinTone
Re: I6 PCV question
You could go to your local parts store and compare. Best bet considering we don't have a pic posted of correct valve. Good luck.
CousinTone is offline   Reply With Quote
Old 07-03-2017, 06:07 PM   #5
TJ's Chevy
TJ's Chevy's Avatar
Re: I6 PCV question
Not the right one for sure, this would be more like it:
https://www.napaonline.com/en/p/CRB29215
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 07-04-2017, 07:10 AM   #6
luvbowties
luvbowties's Avatar
Thumbs up Re: I6 PCV question
I'll bet somebody 'rigged' a pcv-valve to reduce its amount of vacuum. Also bet that when you install a correct one, it won't idle due to 'sucking' too much 'free' vacuum--all due to other end of hose going to incorrect vacuum source. I'd verify a correct source and install correct pcv valve.
Sam
luvbowties is offline   Reply With Quote
