Old 07-02-2017, 07:43 PM   #1
walls
Truck rallys and full hubcaps
I don't know much about hubcaps or how to mount them..
I have 5x5 truck rallys on my 63.
Don't really like the look of them and can't find any stock wheels locally.
Was thinking of maybe putting on some full size caps.
What type of problems am I getting into?
Will any late 50s caps work?
walls is offline   Reply With Quote
Old 07-04-2017, 12:49 AM   #2
AcampoDave
AcampoDave's Avatar
Re: Truck rallys and full hubcaps
Ideally, you coild test fit a cap or two, but.....I can tell you that my Cadillac's caps won't fit just any ol' wheel. They utilize a special kind of balance weight on the rim so as to avoid interference. Also some rims have a lip that rolls inward which prevents the teeth on the caps from locking in.
AcampoDave is offline   Reply With Quote
Old 07-04-2017, 06:52 AM   #3
luvbowties
luvbowties's Avatar
Smile Re: Truck rallys and full hubcaps
I totally agree with ^^^^. Only way to know for sure is to find some* you like and try them. They are installed by merely using a rubber mallet, cost a couple of bucks from Harbor Freight, and rapping along the outer diameter of the cover while holding it with free hand in place (as far as u can make it go onto the wheel with a mild pushing force, said distance not being very far). After hammering in place, they are held by 'teeth' or 'tabs' on wheel covers that bite into the wheel.
BTW: If your rallys do not have their proper center caps bolted in place [held on by 3 bolts per wheel] and do not have their beauty rings installed--you ought to install both on a trial basis. You might be surprised. They never go out of style and, in my opinion, are hard to improve on your truck's looks by swapping them to hubcaps or even aftermarket wheels.
Hope this helps a little: noticed you got NO response from your 1st post--sorry!
Sam
*I am referring to full wheel covers--not the dog-dish type hub caps that cover only ~8" of a wheel's center. (Left-click on ^^^AcampoDave's icon to see the dog-dish type.)
luvbowties is offline   Reply With Quote
Old 07-04-2017, 09:31 AM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
If you need reference to seeing the rally wheel decked out...
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-04-2017, 10:27 AM   #5
Clyde65
Clyde65's Avatar
Clyde65
Rebuild of Clyde
support our troops!
Old 07-05-2017, 07:30 PM   #6
65chevysub
65chevysub's Avatar
These are mine when they were color matched. They are from an 86 Suburban.
65chevysub is offline   Reply With Quote
