Brass water pump fitting?
Does any one know where I can buy a brass water pump fitting like in the picture?
This fitting is for a ¾” heater hose to ½” pipe threads in the top of the water pump. Dorman sells this in steel under part # 56360 but they don’t list it in brass.
Stock 75 C10 step side. 350 2 BBL, 350 trans. 150K miles. |
Plays with trucks
Re: Brass water pump fitting?
I haven't seen them in brass but Spectre makes them in stainless steel. I think I got mine from Summit.
Gary My Dad's Old Truck 1985 ![]() |
Only place I could find one like that last year was from Ebay - all the parts stores just had steel ones. Mine has a barbed end on it instead of that smooth one. It works fine.
Thanks for the replies.
So far I found two different brands on ebay but both only sell in packs of five for $18.00 up. There was one guy that would sell just one for over $50.00. LOL Imperial Brass 92085 Brass Fittings 809J
![]() Join Date: Apr 2009
How come you need Brass? I have one laying around that's OEM cast.
Desert |
I don’t like to use parts that can rust if I have a better option.
Summit has stainless fittings like that, I have used them many times.
Jake thanks for the link but I need a ¾ inch barb.
I give up and will just reuse the old steel fitting.
![]() Join Date: Jun 2012
find a hyd hose shop and tell them what size thread you want you can get it in brass but it will probably have barbs on it which will secure the hose better any way.
Amazon $14.00
Desert |
#13 |
Jake thanks that is the correct fitting that fits my truck.
Summit Performance SS Hose Fitting 1003. Desert1957 thanks I found a brass fitting like in your picture for $7.00 + free shipping in ebay. I will try the $7.00 fitting first.
#14 |
Try the yellow parts bins at NAPA.
