Calling all Experts!
Someone here must know this stuff.
I'm on the home stretch for my '67 396 3OTT Saginaw with OD installation. I need help with my overdrive installation. The governor is missing and I have never seen a photo of an actual unit. A large bolt is installed in it's place. The readily available governor has threads that screw into the overdrive that are much too large to fit. I didn't measure the threads on the bolt, but my guess is that they're about 1 inch. I'm also have a tough time installing my lock out cable. I purchased the factory assembly manual, but couldn't find any info there. The bracket by the T-bar handle is supposed to mount just left of the ignition switch and I've seen photos of it mounted in different locations. I also can't find any photos of where the cable exits the cab. I've been told a hole above the rear wiring harness hole and a hole above the gas pedal. I have the hole above the rear wiring harness, but it's about 3/8". I don't have an existing hole above the gas pedal. I'm also have trouble figuring out where the cable passes the shift linkage. I don't want the linkage rubbing on the cable housing. It's pretty crowded down there with the shift linkage, but I have a lot of room between the tranny and the cab since I used the V8 crossmember. Any photos would be appreciated.
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod |
Re: Calling all Experts!
Some photos:
Lower dash Firewall Shift linkage Bolt where governor should be mounted (don't mind my temporary breather hoses and upside down photo)
Who has the photos?
laying low
![]() Join Date: Mar 2001
Glen here is an OD thread with good pics and wiring info, etc. So far I don't see any pics of cable routing into the cab though.
http://67-72chevytrucks.com/vboard/s...d.php?t=313886
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#5 | |
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod Last edited by ghalperin; 07-04-2017 at 01:02 PM. |
![]() Join Date: Jul 2016
Not exactly on topic but did you read the article about converting the Saginaw 3spd into a 4spd and keeping the overdrive function, or it might have been adding the overdrive to the Saginaw 4spd.
I've read all the posts, bought the April 1975 issue of Hot Rod and I have a fresh Saginaw 4 speed waiting to be installed. I just want to get the OD operational, before I start that mod. 4 OTT.
Its an amazing concept...I had lots of those Saginaw 4spds and 3 spds back in the 1990's, I busted up numerous T5's too, if I would have known about that conversion I would have kept all those saginaws, I didn't have any overdrives but at the time they were very easy to find. I haven't seen any overdrive 3 spds lately but now I am on the lookout.
I ordered the CD version of the factory assembly manual. The hard copy had nothing.
Does anyone have photos or info?
#10 | |
The Older Generation
LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 07-06-2017 at 12:38 PM. |
#11 | |
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod Last edited by ghalperin; 07-06-2017 at 03:01 PM. |
#12 | |
I hope it's big enough. The top hole with no label would be the tail light wiring hole. LockDoc
#13 | |
I revisited the Factory Assembly Manual and found the pages. I must have glazed right over them.
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod Last edited by ghalperin; 07-07-2017 at 12:11 AM. |
#14 |
I'm pretty confident that I have the cable figured out.
I still need to solve the issue with the missing governor. It'll be easier to find it, once I know exactly what I'm looking for. Does anyone know anything?
#15 | |
LockDoc
