Old 07-03-2017, 04:22 PM   #1
Curt - TN
5.3 Vortec Vacuum Ports (2002)
For those who have installed a 5.3 Vortec in your truck did you find any vacuum line routing diagrams on what is needed and what can be plugged?
Curt
Brentwood TN
1950 Chevy 5 Window 3100 - Check out my Build Thread: http://67-72chevytrucks.com/vboard/showthread.php?t=724260
1957 GMC 100
Curt - TN is offline   Reply With Quote
Old 07-03-2017, 09:40 PM   #2
47 Fasttoys
47 Fasttoys's Avatar
Re: 5.3 Vortec Vacuum Ports (2002)
I think the only thing you need is vacuum for the power booster, if equipped. The LS based engines don't use vacuum signals for engine management. Any EGR vacuum and the carbon canister vacuum can both be plugged for stand alone.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 07-04-2017, 10:49 PM   #3
tmoble
do they have a vacuum line for fuel pressure regulator?
tmoble is offline   Reply With Quote
Old 07-05-2017, 07:54 PM   #4
47 Fasttoys
Depends on the year, If a return style fuel rail yes it uses a vacuum line to the regulator. very short molded piece of rubber tube which connects to the intake. The later use a regulator at the pump.
Rob
My '47 C.O.E build
Old 07-05-2017, 08:00 PM   #5
Curt - TN
Rob
Mine is a return system and that little vacuum line and adapter to the small line on the rail is what I am missing
Curt
Brentwood TN
1957 GMC 100
