Old 07-03-2017, 07:27 PM   #1
o-dogg24
transmission swap
I'm new to this site.i have a 71 gmc 3/4 ton 4x4 with a automatic transmission in it. I'd like to change it to a 4 speed.i have 2wd 3/4 ton 4 speeds but I don't think they are the same. can anyone tell me what I all need and have to do to get this done. I'm guessing I'll have to change gears ,and a lot of other things. thanks
o-dogg24 is offline   Reply With Quote
Old 07-03-2017, 09:57 PM   #2
B. W.
B. W.'s Avatar
Re: transmission swap
To convert the 465 from 2 to 4wd you need to replace the main shaft, nut & lockwasher. The t-case adapter replaces the rear bearing retainer
B. W. is offline   Reply With Quote
Old 07-03-2017, 10:29 PM   #3
El Dorado Jim
x2, not hard to do if you have access to a press, better off finding a married unit ready to drop in though....
El Dorado Jim is offline   Reply With Quote
Old 07-03-2017, 10:49 PM   #4
o-dogg24
do you mean just find a 4x4 manual transmission and drive shaft. I'm little slow on the lingo your using.
