lift help 81 k10
Going to be lifting my 81 k10 2 inches and putting 33s on it when i get back from Basic Training and AIT in 6 months or so, and wondering if I will need a transfer case drop, extended brake lines, sway bar drop, or anything like that. I am planning on purchasing the rough country 2 inch lift with rear blocks and front springs. Any input appreciated. pic of my truck below.
Re: lift help 81 k10
rough country is stiffest springs out there = ride suck and cheep price .
go tuff country for a off the shelf kit . and call up offroad design there a great company to deal with for all in 1 kits . anything from mild to extreme setups.
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
for a 2 inch i doubt you will have to change anything. only time i even started running into problems was at a 6 inch lift, even with the 6 inch lift i was able to keep the stock brake lines, though i did cut and twist the metal brake line brackets 90 degrees so they were facing downward to get a bit of extra length.
only thing im not sure on is the sway bar as i always just took mine off |
Thanks for the info, I've thought about tuff country before because ive heard its a much better ride, but from what Ive seen in pictures the tuff country 2 inch lift doesn't look like it really lifts it at all, unless it's just from the pics ive seen. And I've also seen people say that the rough country 2 inch lift isn't that bad of a ride.
Workaholic
Thank you for your service!
You won't need anything for a 2" lift. However, since the truck is getting on in years, and adding 33s will put some additional stress on things I would look at adding a steering box brace from ORD, it's a bolt in.
1979 K-10 Silverado (work in progress) 1991 V1500 Subruban 1999 Suburban LT 4x4 2006 Suburban LTZ (daily driver) |
I just did this w/ORD.What a PIA. got springs from ORD which are Denvers not ORD. They sent me the wrong length rear spring. I had 52's and they sent me 56's, had to move my rear shackle perch 4",that was painful. No suspension changes needed but my castor is now 2 to 3 degrees low on the front and it feels like I am herding chickens. So I now have couple of 3 degree wedges to install which looks like the front springs have to come out to put a new line-up bolt in. Also my front springs are hard against the frame @the shackle and I was sent front shackles 1/2" longer. Got to put those in now. I bought all the stuff like bushed hangers and lubing bolts and a steering brace. Had some labor cost but this is going over 3K. I would not do this again or recommend ORD as I had to do all the research and then argue w/them. Still have to play w/shock length as the 2" lift was more like 5 in the back. All I wanted was a better/smoother ride. This fix did not work.
Your truck looks great leave it alone and save your self a lot of trouble. |
who did you talk with at ord on your problems. ? ?
been dealing with them for years and tons of money for my builds / friends / customers . . . ord special springs are built to ORD SPECS by dever spring yes . somewere someone goofed or got mix matched info . i even had a part problem my fault and i called them and they sold me a new one at the price i paid for the original i screwed up from over 1.5 years before . long term project . they didnt have to discount it but they did and i was happy . for a basic daily driver / mild offroader just stick with off the shelf stuff . if you want crazy flex and old school to ride like new school then yes custom springs are the way to go . its tobad the orignal poster of this thread is in cali . . . me in ny . . . i have a brand new 2.5" lift front/rear springs / shocks i am not going to use . but others have asked on shipping and even fastenal is not doing cali deliverys from my ares .
#8 | |
I don't know why ORD wouldn't pay return postage to fix their mistake. They must be going down the tubes and are barely hanging on if they are that cheap. I put 2" EZ ride springs on my K20. I can't remember the brand name now. No other mods were needed and it drives fine but there is nothing EZ about the ride unless other springs are much stiffer. The ride was actually about the same as the stock springs and no K20 rides that soft anyway.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
These trucks will always ride rough simply because of the design. However, the biggest difference I made to my truck is to get rid of the quad shock setup, it made the biggest difference.
Anyway, I would suggest the 2" ez ride springs from Tuff Country as well they have one of the lowest spring rates and are high quality. This is a good read: https://ck5.com/forums/resources/spring-rate-table.14/
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
As with most situations, there's more to the story. If anyone has questions about how we handled this situation we can talk about it directly.
Hope the OP got his truck lifted by now and can have some fun with it! |
Amen to that. Bashing on a forum is uncalled for, especially a company with a good reputation like ORD (and no, I don't work for them or even know the guys). Nobody's perfect and if a problem occurs I'd think the right thing to do is handle it between the 2 parties... Just my 2 cents.
