BlahBlahBlah
1972 only gauge question
On a 72 what is the most optioned up factory set up you could get on a gauge pod? From my understanding you could not get Speed Minder. I'm talking 1/2 and 3/4 tons, standard or 4x4 pick up only, so nothing from the bigger trucks
My guess vacuum and air only came on the bigger trucks. Also not talking about delete stuff, like choke delete plate. Does anyone have a maxed out gauge pic they can show?
Roadtrip!
![]() Join Date: Feb 2003
Re: 1972 only gauge question
1/2 and 3/4 ton would have the 7 gauge cluster with one being blank (lower right) and a tach in the middle.
Speedminder was done in 69, and air and vacuum were c-40 and up. Choke deletes were gone in 69.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
BlahBlahBlah
I guess if they didn't have choke deletes they probably didn't have chokes either. How bout manual throttle? That's the only other thing I can think of
Why was speed warning no longer available? I have it in my '70...
Mine's now maxed out but like everyone and their dog I added a vacuum gauge, which I will replace with an air pressure gauge if/when I find a good one. But that hole should be vacant even on a maxed out stock one, right?
I believe your correct, I had a 72 CST K5 blazer that came with factory tach and manual throttle. Here is a pic of the SPID.
Michael ![]() |
All about them K’s
![]() Join Date: Jun 2014
I've seen a few 72's with the manual throttle setup listed on the spid and still intact on the truck as well.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
![]() Join Date: Mar 2000
My 72 had a factory manual throttle.
Saskatoon, Saskatchewan Canada |
Roadtrip!
Yes, manual throttles were available in all years. I think I have seen them on both sides of the gauge cluster also. Most 72s I have seen were on the right side of the column.
