Old 07-04-2017, 02:30 PM   #1
inline67c20
Junior Member
6 Qt oil pan
I've done a couple searches and can't find an answer to my question. Will a 6 qt oil pan on a small block fit in a 67 c-20? And is there really that much benefit to have a 6 qt pan?
I bought a mildly built 350, it has a 6qt oil pan on it. what I should have asked will it clear the cross member, or should I use the oil pan off the 327 that was originally in it?
inline67c20 is offline   Reply With Quote
Old 07-04-2017, 04:21 PM   #2
Shaky
Six in a row makes it go...
Shaky's Avatar
Re: 6 Qt oil pan
Not sure what the benefit might be other than cooling. Small blocks have a pretty good oil system. I don't think much of Fram filters these days, but the PH373 will screw on and adds about a quart. I think the Wix equivalent is 51794.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 07-04-2017, 04:40 PM   #3
leftybass209
leftybass209's Avatar
Re: 6 Qt oil pan
Will it fit, really depends on which brand you use. I'd see no benefit to just increasing the oil capacity of a street driven vehicle. It'll just run up your oil change tab by about 3-5 bucks for the extra quart. If heavy hauling or towing is in the trucks future, an oil cooler would be a more practical investment.
leftybass209 is offline   Reply With Quote
Old 07-04-2017, 04:52 PM   #4
6T7 C10
Re: 6 Qt oil pan
If you are referring to a stock 5 qt pan + 1 qt filter vs. a 4 qt pan + 1 qt filter then yes it will fit.
6T7 C10 is offline   Reply With Quote
Old 07-04-2017, 05:32 PM   #5
Shaky
Shaky's Avatar
Re: 6 Qt oil pan
Sorry if I confused the thread with the oil filter bit.
OP is asking about a 6 quart pan only.
I'd put the 5 quart pan on the mild 350 and call it a day.
Old 07-04-2017, 07:46 PM   #6
inline67c20
Junior Member
Re: 6 Qt oil pan
Thanks for the info, I will take the oil pan off the 327 and use it.
Old 07-04-2017, 07:52 PM   #7
hayhauler71
hayhauler71's Avatar
Re: 6 Qt oil pan
A milodon 30401 pan will fit
Fuzzy
hayhauler71 is offline   Reply With Quote
