Old 07-04-2017, 03:54 PM   #1
craneboy72
craneboy72's Avatar
Hatch hinge grommet help
I have a 71 k5. I removed the hatch to replace the gasket around the entire outside edge. I also removed the grommets at the hinges both on the hatch and roof side. I have purchased new grommets from several different vendors. They look correct for the hatch side but not the roof side. Does anyone manufacture the roof side grommet? I am saying grommet because they are the style that push into a hole not the one with 2 screws. Any help will be welcome
craneboy72 is offline   Reply With Quote
Old 07-04-2017, 04:06 PM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Hatch hinge grommet help
Any pics of new and old gaskets/grommets? There are two styles of the hatch side grommets/gaskets. I thought the top side gaskets were all the same and similar to one of the two hatch styles. Pic shows the differing hatch styles.
Old 07-04-2017, 04:32 PM   #3
craneboy72
craneboy72's Avatar
The black ones are new and the white ones are off the top side of the hinges. There is a narrow and wide side if I put the narrow side up the bevel on the inside is going in the wrong direction if I put the narrow side down it will not fit. As u can see the old ones also have an extra boss not sure if that matters?
Old 07-04-2017, 04:48 PM   #4
1rippen6
I didn't forget about you I just ordered another parts manual off ebay for 38-69 was hoping it would be in there. I missed it the first time and he just relisted it should be here by the end of the week. Keep your fingers crossed LOL.
1rippen6 is offline   Reply With Quote
Old 07-04-2017, 04:58 PM   #5
craneboy72
craneboy72's Avatar
Thanks Dwayne still trying to sort it out
Old 07-06-2017, 09:54 PM   #6
1rippen6
Bad news the catalog has no illustrations and I don't have a clue where to look. To top it off I don't see any blazer info just suburban and truck sorry.
Old 07-07-2017, 04:37 PM   #7
craneboy72
craneboy72's Avatar
Thanks again Dwayne I am surprised nobody else has had this issue
Old 07-09-2017, 07:59 PM   #8
craneboy72
craneboy72's Avatar
Update: I installed the new grommets with the wide side up. They fit fine and the hinges slide in with a lot of dish soap. Everything is good, I guess I was over thinking it thanks for all the input.
Old 07-09-2017, 11:21 PM   #9
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Good to know thanks for the update. I'm curious if the style that makes use of the retainer and two screws is reproduced: I have a single wall top here that has this style on both the hatch and top sides and a double wall that used the two screw style on at least the top side.
Old 07-15-2017, 08:46 AM   #10
craneboy72
craneboy72's Avatar
Deadheadmn they do reproduce the rubber with the 2 screw holes I bought a set of rubber that I can send u if u want them I have no use for them PM me your mailing address and I will send them to you.
Old 07-15-2017, 09:35 AM   #11
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks!! I appreciate the offer. PM sent. Pete
