Old 07-04-2017, 08:01 PM   #1
custom10nut
custom10nut's Avatar
String Alignment method
I finally got around to aligning the truck Before I take it to a shop.
I used the string method that was detailed here on another thread.
It real easy to do.
I had my son hold the steering wheel tight while I made the adjustments.
I'm kinda curious how close I have it before putting it on a machine.
custom10nut is offline   Reply With Quote
Old 07-04-2017, 09:53 PM   #2
bigrigpardo
Re: String Alignment method
after years of doing this stuff its a good way to get it close enough to safely drive to the front end shop but unless you have sliding plates under the wheels its hard to be accurate because the wheels will pull themselves to try to keep straight.
bigrigpardo is offline   Reply With Quote
Old 07-04-2017, 10:31 PM   #3
custom10nut
Yeah, I thought about that while adjusting the coolers, and had the son turn the wheel back and forth an then checked again. After getting the same measurements three times, I called it good. We'll see I guess
Old 07-04-2017, 10:40 PM   #4
EARNHARDT#3
EARNHARDT#3's Avatar
Here in PA I'd never pay for an alignment. The roads are so bad it would be knocked out of alignment in no time. I just eyeball it and adjust after driving if it's twitchy.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 07-13-2017, 01:45 PM   #5
rockyrivermark
Last time I did that the alignment shop said it was dead on
One this I did was drive the front tires onto a piece of scrap laminate, approx
10 x 12"Smooth side down then the tire doesn't bind on the concrete floor.
A piece of sheet metal stock would prob also work.
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 07-13-2017, 02:58 PM   #6
bill3rail
bill3rail's Avatar
Simple? Yes.
Cheap? Yes
Efficient? Yes
Major Score in my book!
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 07-13-2017, 07:29 PM   #7
custom10nut
After reading this, I'm going to use the smooth surface method, and check it again. I have plenty of sheet metal that I can use.
Old 07-13-2017, 07:50 PM   #8
randy500
I just aligned mine on my smooth garage floor, to reduce tire friction I placed a double layer of plastic sheeting under each tire seemed like zero friction. I wired 1" square sticks to my rally wheels to measure toe in, drives great now
randy500 is offline   Reply With Quote
