65c10
What radiator is everyone using 355 sbc?
I bought one for 65 but it seems to be way to big 25 1/2wide x 23 1/4 tall |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: 65c10
The size sounds about right. Are you trying to put it down between the frame rails in the I6 radiator location?
Re: 65c10
I thought that's where it would go when I bought it. But I see it won't fit Just wondering what everyone else is doing?
60-66 Nut
Re: 65c10
The I6 HD cooling and V8 radiator sits on top of the frame. There needs to be the lower saddles for it to sit in. There is a different top hold down bracket, plus the side shrouds that the fan shroud attaches to.
Re: 65c10
So what would you recommend Captain Fab?
Thanks for your help |
60-66 Nut
Re: 65c10
Install the radiator in the location it is meant for and with a shroud.
Re: 65c10
Ok thanks wonder if there's any pictures any where?
I planning on electric fan |
60-66 Nut
Re: 65c10
There are lots of pictures here in the projects and builds section as well as the '63-'66 message section.
