Old 10-24-2003, 08:52 AM   #1
Estanley
Estanley's Avatar
Angry Transmission cross member???!!!
Aren't there only two different crossmembers for the C10. The one that bolts to the bellhousing of a manual and an automatic crossmember that bolts to the tail of the trans?
I dealing with a local yard trying to locate one for my bro-in-law to convert from a 3sd. man. to a th350 short. Well the yard called and asked wether I had a th350 or th400 because they were different. I was under the impression that the crossmember was the same it just bolted to different holes in the frame.
HAVE I LOST MY MIND? Any help is appreciated.
Estanley is offline   Reply With Quote
Old 10-24-2003, 09:18 AM   #2
JimKshortstep4x4
Talking
I believe that there are differences in the cross members because of the emergency brake setups. I have never compared them that close. Now you have me curious and I will have to look.
Jim
Old 10-24-2003, 09:44 AM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
I'm going to go out on a limb here ans state that any 1/2 ton or 3/4 ton th350 or th400 crossmember will work, just by moving it to the correct frame hole location.
I have seen th400 equipped trucks that have an extra bracket bolted to them. This bracket is like a wiring harness hold-down and the intermediate E-brake cable passes thru it. I presume it is required because the th400 location sits further back.
In short, I would't hesitate to purchase either style and use it interchangeably.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 10-24-2003, 09:59 AM   #4
JimKshortstep4x4
Talking
CPNE,
Where is a saw when you need it?
The two clips are the differences that I remember and that might change the number of the cross member. I have both cross members and I plan on looking at them tomorrow as I am not sure if there are other differences. I agree with you that one will work for the other.
Jim
