How to fix radiator leak
My radiator appears to be leaking where one of the tubes is soldered into the tank. How do I fix this? Soldering? JB Weld?
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
Post Whore
![]() ![]() Join Date: May 2015
Re: How to fix radiator leak
Buy a new one..that's what I did..got one from oreillys cheap as the quote to "try" to fix mine...
JB weld. if that does not hold then just get a new one.
This is a 4 core radiator with copper tanks for heavy duty applications. Who sells a similar radiator for low cost? I don't really want a radiator with plastic tanks since vehicle is used for towing in very hot climates.
![]() Join Date: Feb 2014
If you can get to the leak, clean it very well, use flux and sweat in some solder. Bruce
Posted via Mobile Device |
#6 | |
If you have an old school radiator shop still in business, they should be able to boil it, fix the leaks, pressure check it, and paint it.
-Peter 1978 K10 stepside |
My truck had a Harrison radiator in it when I bought it. I went to a "old school" shop and they wanted over 400$ to re-core it I bought a spectra from summit for 104$ and it does fine in the California desert heat.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
Keep in mind that if that radiator is fairly old(20+ years), other leaks may be a short time away. You could wind up playing a version of whack a mole with leaks. How many times do you want to drain coolant, pull the radiator, clean, repair, reinstall, and refill?
2nd Peter S's suggestion on a old style radiator shop. See if and what they charge for a good test. Might try some stop leak. I used some when my heater core started leaking after winter cold had started. Delayed the inevitable about a year and a half. At least it was spring when it gave up. |
Good luck if you can find a radiator shop that would attempt to re-core. The original radiator on my 74 was not leaking, I wanted it re-cored and could not find radiator shop that would touch it due to it did have previous leaks repaired. When they saw the greenish color from past leaks, they said no way. Ended up replacing with aluminum a few months ago, no problems since here in Texas heat.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
Post Whore
I had the old school radiator shop look at mine...they said maybe maybe not..couldn't guarantee it..mine wasn't leaking but you could look down thru the fill hole and see the flutes were stopped up...it would take 15-20 min to drain it...it was still cooling I just wanting it cleaned..they said cleaning may cause more problems than its worth...aka wackamole...I got a wide core aluminum from O'Reilly for just over 100 bucks. ..it cools fine and Im pulling a 9k loaded trailer in alabama heat...my temps never get over 185..
My truck had a plastic one and I wanted a copper/brass one. Looked like 600.00 new and shipping but I went to the salvage yard found one that looked for a "C" note. I'm happy.
#13 |
Do these low cost plastic tank radiators cool as well as these old school 4 core brass tank radiators? I've got a diesel engine in my truck and it needs every bit of cooling possible.
#14 |
Post Whore
Mines not diesel...but it was a 350 and now its a 6.0 lq9..new radiator cools just fine..like I said pulling a 9000 lb loaded trailer...a diesel may be a different story
#15 |
Thanks for the replies. Instead of fixing this radiator, I picked up a used radiator out of a 1984 diesel Suburban for $50. It looked a lot better than mine and I found no leaks when I did a pressure test on it. Not sure if it was replaced at one time or not but I notice that it doesn't say Harrison on the side of the tank and it has a plastic drain plug. My guess is that it has been replaced.
I might have been alright with a new plastic tank radiator but plastic worries me because my experience with them is that they don't just start leaking slowly, they crack big time and leave you stranded on the road. My area has very hot temperatures and those with the newer trucks complain about their plastic tank radiators blowing up. I am going to give this radiator a good cleaning before installation. Then I will try soldering my leaky radiator. ![]()
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift Last edited by Edahall; 07-07-2017 at 12:06 AM. |
#16 |
This used radiator that I acquired was full of scale. So I poured a gallon of Muriatic Acid and let it set for about 30 minutes. Many big chunks of scale came out as I flushed it out.
Before ![]() After ![]()
#17 |
Used radiator has a leak in one of the tubes. This was on the side with the grill so I most likely missed it when I performed the pressure test.
#18 |
![]() Join Date: Sep 2016
Cleaning an old one like that may have caused the leak. Soldering may be tough in that spot. Good luck with repair.
#19 | |
![]() Join Date: Jun 2016
These 800hp desert race guys have gone to aluminum 2 core units. If you are scared of plastic tanks then call up Ron Davis and get one with welded aluminum tanks. That is what I have in my Jeep and again zero cooling issues.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
#20 |
Most modern trucks have plastic side tanks and have performed fine. I have a GMC 2000 sonoma and replaced radiator a couple years ago. I think 15 years was not bad for a 173,000 mile truck. I also had used Bars leak in it since the leak developed in the winter time and I did not want to mess with it till it got warmer. I will say bars leak works pretty good and have even heard a raw egg works as well lol. I would trust bars leak over an egg though, ran bars leak in a NOva for 2 years. Anyway I digress a plastic radiator I bet would be cheaper and less frustrating in the long run but good luck.
79 Chevy 2wd BIG10 350 TH400 |
#21 |
If you are decent with soldering copper pipe, should be able to fix the leak on the 2nd radiator. Just clean the outside real well. Might help to cut out a couple of the fins around the leak. At this point, you don't have much to lose. If nothing else, just crimp shut that row at the leak and solder the crimp.
