Old 07-06-2017, 12:35 AM   #1
NWSooner
Factory Carb Metering JET size ?
Greetings friends, I'm back for more help, I know its been a month but I have not forgotten all of the excellent responses from my original question, thanks again!
Here is the deal:
The truck is still running a bit to rich and I think it's because of the incorrect JET SIZE in the carb, does anyone know what size my 66 C20 w/Inline 6 250 Rochester 1 barrel should be? The size stamped on current Jet is .071
Thanks in advance
NWSooner
NWSooner is offline   Reply With Quote
Old 07-06-2017, 01:21 AM   #2
NWSooner
Re: Factory Carb Metering JET size ?
Never mind I just found this crazy helpful web-site: http://www.carburetor-parts.com/B-BC...es_ep_524.html
Looks like I need an .058
Cheers friends,
Old 07-06-2017, 02:29 PM   #3
chevylookin
Yeah, sounds like you might be running a bigger carb jet on your 250. Are you sure you have a (stock) 250 and not a 292 or perhaps your 250 got worked on by a PO and he bored the block out alot or did some head work or put in a lumpier cam or a combination of the sorts and put a bigger jet for more fuel demand? It could also be that someone in a pinch just needed a a 1bbl Rochester and threw whatever they could find on the intake. I am not very knowledgeable when it comes to metering fuel on carbs. TJ's Chevy would be very helpful on this scenario. Hopefully he can chime in soon.
chevylookin is offline   Reply With Quote
