Old 07-07-2017, 03:48 AM   #1
az1970k5
az1970k5's Avatar
Correct intake manifold gaskets
Did a search but couldn't find any useful information regarding this. I have an edelbrock performer intake on a 350 with a quadrajet. I didn't have any leak issues but I decided to freshen things up a bit. Now I am wanting to put the correct intake manifold gaskets. My manifold and engine have the intake crossover ports. The PO had these open. I noticed some mechanics recommend these be open and some recommend them to be blocked off. My question is which way is the best and what mainifold gaskets are recommended? I live in AZ so getting to operating temperatures is not a big deal as it gets 110 in the summer and no less than 45 degrees in the winter.
az1970k5 is offline   Reply With Quote
Old 07-10-2017, 09:00 PM   #2
Anejo
Re: Correct intake manifold gaskets
You're best blocked off especially given your climate. The manifold will thank you for it. Some might argue the Q'jet won't work right without the heater. I never found it to be the case. The felpro gasket sets have a block off in the set.
Anejo is offline   Reply With Quote
Old 07-10-2017, 10:27 PM   #3
az1970k5
az1970k5's Avatar
Thank you
