07-07-2017, 10:15 AM | #1 |
Changing GMC grill to Chevy Grill on 70 Chevy
I just bought a '70 C10 LWB. It currently has a GMC grill and core support on it. I'm going to change this to a Chevy grill and I'm looking for any suggestions to make this as easy as possible.
HELP...!!!!! |
07-07-2017, 10:20 AM | #2 | ||
"I ain't nobody, dork."
Re: Changing GMC grill to Chevy Grill on 70 Chevy
You'll probably need 1969-1970 C10 front fenders as well as a core support. GMC used the same front fenders and core support from 1968-1972.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
07-07-2017, 10:54 AM | #3 |
The truck is actually a '70 Chevy, so it already has the Chevy fenders. The PO had the front grill and core support stolen off the truck and went back with GMC support and grill at some point b4 I purchased it. I've read on some posts that I can remove the two inner buckets and that should be close to all is needed...
07-07-2017, 12:41 PM | #4 |
If you remove the entire headlight bucket bracket from the gmc you can install the bucket itself to the core support from a Chevrolet by drilling the square holes for the adjuster screws.
07-07-2017, 12:42 PM | #5 |
The basic stamping is the same on both core supports, its best to have a chevy one even if rusty on hand for reference
07-07-2017, 01:52 PM | #6 |
Thank you Randy 500 for the advice
07-07-2017, 01:56 PM | #7 |
what about the headlights themselves? the GMC headlights are smaller than the Chevy headlights. will the headlight size cause a problem?
07-07-2017, 04:17 PM | #8 |
You will need the headlight bracket with bucket, the spring and 2 adjuster bolt a from the chevy core support. The picture shows the bracket. The bucket springs and adj. bolts are missing
07-07-2017, 04:20 PM | #9 |
Gmc bracket configuration. pic shows gmc small headlight bucket adjuster bolts etc
07-07-2017, 04:22 PM | #10 |
I am doing the opposite
I am putting the gmc headlights on that chevy core support |
07-07-2017, 04:24 PM | #11 |
What is the condition of the GMC grille? What are your plans for it?
I have a 70 GMC and need a grille (but not a radiator support).
1970 GMC K2500 Dis-use is harder on a car than mis-use. |
07-07-2017, 04:29 PM | #12 |
I have done it before and the best was is to assemble The Whole front end and grill with the headlight Brackets loose, then center headlights in grill and tack weld buckets to core support. Hard to get them centered unless done that way
07-07-2017, 04:36 PM | #13 |
$167 from truck and car shop for a new Chevy core support sounds like a deal.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
07-07-2017, 06:24 PM | #14 |
07-08-2017, 02:46 AM | #15 |
07-08-2017, 06:31 PM | #16 |
07-11-2017, 12:37 PM | #17 |
Sending you a PM.
