Old 07-08-2017, 01:06 AM   #1
Brad54
Brad54's Avatar
60-62 auto trans crossmember: short and longbed different??
I just read where someone posted that the auto trans crossmembers for 60-62 X-frame trucks, are different if the truck is a long bed or short bed.
Why? The orientation of the trans into the x-frame isn't any further back on a long wheelbase truck... it's in the same place under the cab...
So are there two different autontrans crossmembers or just one?
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 07-08-2017, 11:12 PM   #2
Captainfab
60-66 Nut
Re: 60-62 auto trans crossmember: short and longbed different??
In a short wheelbase frame the 'X' in the middle is farther forward than in a long wheelbase frame.
Old 07-09-2017, 03:06 AM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
I inadvertently picked up a long wheel base cross member years ago for my short stepside frame. I had it sectioned about 3-4 inches to fit my frame correctly. I also had 1/4" angle fitted over the sliced area for additional strength.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 07-09-2017, 09:12 AM   #4
runningiron
runningiron's Avatar
Brad54, I just sent you a pm. Thanks Bob.
runningiron is offline   Reply With Quote
Old 07-09-2017, 12:50 PM   #5
oldusafmsgt
oldusafmsgt's Avatar
Shortbed 60-62 auto crossmembers are shorter overall length than a longbed auto crossmember. Both are rare as hen's teeth and expensive when they can be located. Unless doing a 100% factory original restoration, one can be fabricated up pretty easy.
1960 Chevy Apache10 Short Fleetside
1961 Chevy Apache10 Short Fleetside
1961 Chevy Apache20 Fleetside
1963 Chevy C10 Short Fleetside
1965 Chevy C10 Short Stepside
1965 Chevy C10 Long Fleetside
1966 GMC 1000 Long Fleetside
1966 Chevy C10 Short Fleetside
oldusafmsgt is offline   Reply With Quote
