07-08-2017, 01:55 AM | #1 |
Inner roof help.
I have a few questions. Can the inner roof be replace without removing the roof? Can somebody show me some pictures? Is there a thread that shows how is do?
07-08-2017, 09:20 AM | #2 | |
The Older Generation
Re: Inner roof help.
LockDoc
07-08-2017, 12:13 PM | #3 |
Yes you can. Is the cab still bolted to the frame? It's a lot easier to install if you can roll the cab on its firewall to replace. That way your not working overhead.
www.nsanehotrodz.com customerservice@nsanehotrodz.com 865-761-0460 Tennessee's #1 HotRod Shop! |
07-08-2017, 12:26 PM | #4 |
My truck is a c20 and the previous owner didn't do a good job patching the holes on top of the roof. The inner roof panel rusted out so now I need to replace it. I found a donor roof but I think that my water drip is a lot better than the donor one. what I really what to find out is if the rear part of the inner roof panel has spot welds or is it glue to the inner window panel. Sorry I don't know what it's call. Yes the cab is bolted to the frame
07-08-2017, 01:15 PM | #5 |
Six in a row makes it go...
I've never seen the inner roof taken out. You can click on my '67 build thread below and see some pics of what it looks like with the outer roof taken off. There were a lot of spot welds...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 The height of sophistication is simplicity." - Clare Boothe Luce |
07-08-2017, 01:16 PM | #6 |
The rear headliner seam is spot welded.
Cutting out the headliner is not bad at all, 2 hour or so to cut all the spot welds, I have done at least 2 of them, pics probably in my crew cab build thread |
07-08-2017, 01:18 PM | #7 |
At least 20% of the spot welds just aren't attached or barely attached, I insert a screwdriver by each spot weld and pry before drilling, saves some drilling, they also make a spot weld splitting tool, like a knife that would be helpful
07-08-2017, 01:52 PM | #8 |
The Assembly Manual shows all of the spotwelds. Here are a couple of shots that show the areas you are wondering about. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 07-08-2017 at 02:32 PM. |
07-08-2017, 11:41 PM | #9 |
It took a little bit of time but I removed the inner roof. Thanks for the info. I am going to try and replace the inner roof panel tomorrow.
07-09-2017, 01:23 AM | #10 |
Good job post some pics
07-09-2017, 03:17 AM | #11 |
I'm going try and post the pictures tomorrow if I can finish.
07-09-2017, 05:08 AM | #12 |
That is pretty awesome, thanks for posting the pic. But how is the back of the headliner panel attched to the rear cab panel ?
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
07-09-2017, 01:36 PM | #13 |
Is attached with spot welds. I did the spot welds around the windshield frame first then the doors and then the back. I used a putting knife then a chisel and the a cutting disc. It was easy. I hope putting the other one in is the same way.
07-12-2017, 11:44 PM | #14 |
It was easy, the back of the inner roof panel has weld spots so the only thing that I can do is add some seamseal.
07-13-2017, 02:39 PM | #15 |
BlahBlahBlah
Didst efabman take a members cab down to nothing, every part separated. Not sure who posted it efabman or the member.
