Old 07-08-2017, 11:46 PM   #1
jsweeney57
AccuAir E-Level issues
Hey there!
I own a 57 Chevy pickup. recently installed the AccuAir E-Level air ride system. Worked perfect for about 2 weeks, now my compressors won't shut off. Contacted AccuAir, who were very accommodating. Shipped back the ECU, Touchpad, and usb cable for testing. Testing came back good. No issues with ECU, Touchpad or cable. Any ideas?
I'm thinking maybe a loose ground? Could it be that simple?
Thanks for any and all assistance.
John Sweeney
jsweeney57 is offline   Reply With Quote
Old 07-09-2017, 01:14 AM   #2
AccuAir_Reno
Re: AccuAir E-Level issues
It's possible that your compressor relay is just locked ON. This is easy to test with a test light... Check the voltage on the yellow wire coming from your ECU to your compressor relay. If it is OFF when your compressor is ON then your relay is locked ON. Sometimes you can just smack it and it will go back to working like normal.
AccuAir_Reno is offline   Reply With Quote
Old 07-09-2017, 07:35 PM   #3
jsweeney57
Thanks AccuAir_Reno!! I'll be working on it this week and let ya know how it goes. Strange how it all worked perfect and then all of a sudden, this problem haha.
Old 07-11-2017, 09:56 AM   #4
68is4me
68is4me's Avatar
My money is on a stuck relay. Are you running just one comp? Are you using the relay from Accuair? If not make sure the relay is bigger than the amp draw for your comp.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Old 07-11-2017, 10:19 AM   #5
jsweeney57
Update: I reinstalled the ECU, touchpad, and usb cable. While under the truck, I found a questionable ground coming off the ECU. Fixed that ground and it seems to have remedied the problem. I also gave the relay a smack in case it was stuck on stupid haha.
NOW, while trying to recalibrate the system, (which accuair says shouldn't take longer than 15 minutes) the touchpad heats up bad and was blinking and calibrating for over 40 minutes yesterday.
PS- I have 2 compressors. All components are from AccuAir.
Really appreciate the assistance guys!!! You rock. Thanks 68is4me.
John Sweeney
New York
1957 Chevy Truck
454/700R4
Old 07-11-2017, 10:36 AM   #6
68is4me
68is4me's Avatar
The touch pad does get warm. It should not take that long to calibrate. Check for air leaks. Are the compressors running all the time? When I do mine the comps will run for about 5 min then shut off, then it starts doing all the level adjustments.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
Old 07-11-2017, 11:01 AM   #7
jsweeney57
No leaks. Truck is at ride height for a few weeks now. When I power the truck, the touchpad lights up all white. I press menu and #2 and hold them to start calibration. Compressors kick on for about 2 seconds, then touchpad lights start to do their flashing. That's it though. Truck doesn't adjust height or anything.
John Sweeney
New York
1957 Chevy Truck
454/700R4
Old 07-11-2017, 04:07 PM   #8
jsweeney57
I'm wondering if there is some sort of universal "reset" option so I can start from scratch with the calibration. maybe it's recognizing the old settings. Also, should the bags be empty at time of calibration? Truck sitting at ride height may be confusing the ecu. Just a guess.
John Sweeney
New York
1957 Chevy Truck
454/700R4
Old 07-11-2017, 04:36 PM   #9
68is4me
68is4me's Avatar
Your doing this to calibrate right? Every time you recalibrate it will use the relearned settings. Don't matter if bags are full.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
Old 07-11-2017, 10:27 PM   #10
jsweeney57
Old 07-11-2017, 10:30 PM   #11
jsweeney57
Originally Posted by jsweeney57 View Post
Yup. Pressing #2 and menu dot button at same time, wait til they flash. Compressors respond by kicking on, then turn off. Then lights strobe for a while. When calibration is complete, #2 should stay solid. But that never happens haha. At least for 40 minutes it hasn't.
Old 07-12-2017, 08:51 AM   #12
68is4me
68is4me's Avatar
Do the lights strobe in red? If so that a low voltage issue. If not I bet you have a pressure issue maybe a bad pressure sensor.
I would start from ground zero and double check everything to make sure it is all wired correctly and installed correctly and call Accuair. Maybe post some pics maybe it something easily spotted.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
Old 07-13-2017, 09:39 AM   #13
jsweeney57
No red strobes. Just the 1 2 & 3 buttons are flashing constantly. Kind of looks like it's doing what it's supposed to.. Just waaaaay too long.
John Sweeney
New York
1957 Chevy Truck
454/700R4
Old 07-13-2017, 10:06 PM   #14
jsweeney57
UPDATE: Spoke with AccuAir tech support today. Turns out, their manual has an incorrect connection on one of the ground wires haha. I always suspected this ground was a little funky. The manual had me wiring a ground to the aluminum mounting bracket for the air manifold. As soon as I ran that ground to the frame, the truck came to life. Fully calibrated and fully functional now. Thanks for all the assistance everyone!!! Truly appreciated!!! I'll post a pic of the truck taken this afternoon.
John Sweeney
New York
1957 Chevy Truck
454/700R4
Old 07-13-2017, 10:22 PM   #15
jsweeney57
Not sure why the pic keeps posting upside down haha.
John Sweeney
New York
1957 Chevy Truck
454/700R4
accuair
