![]() Join Date: Jan 2001
Parts for sale! PS. Auto non tilt column, etc...
Hi all,
Have some parts I would like to move: I have: - P/S pump, with all sb brackets, and pully. $60 obo - Set of 6 lug rally rims, with trim rings but only two caps (4x4 type), with mounted Bridgestone Deuler tires with less then 5000 miles - $200 - Complete 70 non A/C cab, with little rust on outer rockers, cab corners, and two small rot holes at the bottom of the side of the cowl. $150 - 2 x used HEI distributers, unknown condition, but they seem to function normally, just haven't used them $15 each - Quadrajet for a '70 sb truck, needs rebuild $25 - Drivers side saddle tank, this is the one WITHOUT the sending unit $30 - Cowl off of a '70 decent shape $25 - Imperial (branded on the switch end) 3 tank switch mounted in cab floor on drivers side, seems locked up, but may be rebuildable $15 - Used Edelbrock torker manifold. Could use a beed blasting $25 - Holly 600CFM carb, needs rebuild $25 - 69/70 Chevy Grill (Complete) - Outer grill has all the black faded off, but is in nice shape. Inner grill has a few broken spots, will include turn signal setup as well as headlight trim (the headlight trim has some surface rust) - $100 - 69/70 hood - $25, come get it. - Drivers side inner fender, good shape, no rot, could use sanding and paint - $25 - 69/70 Front Fenders (both), they both need the lower patch panels as far as I can tell, $40 for both of them. I am not willing to ship the rims/tires, the cab or other LARGE parts. UPDATED, lower prices..... Thanks, Orlando
70 C-20 Custom Camper Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=300251 Last edited by oteixeira; 10-28-2003 at 10:23 AM. |
Keep On Truckin'
I'll buy the intake. Ley me know shipping to business address in zip code 78744 (Austin, TX).
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
KEEP ON TRUCKING
how much shipping for the x member and column to 24055 where is wilson im in martinsville va thx
72 cheyenne 2wd lwb 71 k20 sons bassett va |
steering column
Auto stearing column, all that is wrong is the plastic part from the indicator is missing $30 obo
Do you have all the linkage for an automatic also?
Bryan@ideamill.net 71 Chevy Custom 20 Suburban 69 Chevy Camaro |
Anwsers
72shadetree,
Wilson is right off of I-95, exit 121. I would have to figure shipping, I will PM you with them amount unless you tell me you are going to come pick them up here. 69&72Bowties, I am sorry, no auto linkage.... Orlando
70 C-20 Custom Camper Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=300251 |
KEEP ON TRUCKING
let me know on shipping thats a good distance from here
Postage amounts
Hey,
Mocwon-The intake shipped to your door would be: 15.31 normal 19.75 Priority So total cost would be either 40.31 or 44.75 72shadetree: the two parts (column and crossmember) shipped to your door: 15.29 normal 25.95 priority (we are so close I see no reason to pick this) So total cost would be either 70.29 or 80.95 Thanks guys...If you want them let me know, and I will pm you an address to send a money order to. Orlando |
Trying to stick with it
IS this the ps bracket you have, if so what would shipping be to 30360
69 Chevy C10 LWB somewhere in the pile of parts in my garage. 01 Cadillac STS as daily driver |
KEEP ON TRUCKING
thanks sent you a pm consider the column and x member sold
P/S stuff
69C10Atl,
Yup, thats it. Plus the pump and pully. It will be $12 to ship. So that is $87 if you want it, pm me for my addy if you want it. Orlando
PM sent!
PM Sent!!!!
Mail is full
BigBlockBurris,
Tried to PM you back but your box is full...... |
#13 |
PM box
Sorry about that. It's empty now. Thanks
BBB ![]() |
#14 |
BBB, you now have a PM
Orlando |
#15 |
Bump - added stuff & lowered prices
BUMP
#16 |
KEEP ON TRUCKING
sent mo yesterday for the other stuff
would you ship inner fender if so how much 24055
#17 |
72,
Not sure it would be woth shipping to you, It is big, and odd sized, and may almost double in cost if I were to ship it. Sounds like you just need to make a weekend trip to my place! ![]() Orlando
#18 |
KEEP ON TRUCKING
thanks pm sent
#19 |
Do you have a picture of the outer grill?
Someday I might get my truck running again =( |
#20 |
Pictures
Bryon,
With the time change and all the rain I have been having a hard time taking pics, but I will see what I can do for you. Orlando
#21 |
#22 |
Pics of the grill
If they dont show up follow these links: http://www.geocities.com/oandcteixeira/DCP_0010.JPG http://www.geocities.com/oandcteixeira/DCP_0011.JPG http://www.geocities.com/oandcteixeira/DCP_0012.JPG http://www.geocities.com/oandcteixeira/DCP_0013.JPG http://www.geocities.com/oandcteixeira/DCP_0014.JPG http://www.geocities.com/oandcteixeira/DCP_0015.JPG http://www.geocities.com/oandcteixeira/DCP_0016.JPG Orlando
70 C-20 Custom Camper Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=300251 Last edited by oteixeira; 11-02-2003 at 11:33 AM. |
