Old 07-10-2017, 04:54 PM   #1
Bagged1972
Disc brake spindles
Hey all, I'm wanting to put disc brakes in my 1963 GMC and I really can't afford new spindles but I have a set of spindles from a 72 C10 and I was wondering if they will work if I change the ball joints to match the 72 spindles?
Bagged1972 is offline   Reply With Quote
Old 07-10-2017, 11:13 PM   #2
Captainfab
60-66 Nut
Re: Disc brake spindles
Yes that will work.
Old 07-11-2017, 03:09 AM   #3
Bagged1972
Originally Posted by Captainfab View Post
Yes that will work.
Thanks I was beginning for wonder if anybody was gonna reply... Lol
Old 07-11-2017, 11:40 AM   #4
Chevy Fleetside
Chevy Fleetside's Avatar
http://www.67-72chevytrucks.com/vboa...isc+brake+swap Here I used spindles from a 75. Pretty much the same process. Don't know about the tie rod end on a 72 verses a 75 though.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 07-11-2017, 01:09 PM   #5
Bagged1972
Nice and thanks for the info but What is the part number for those tie rod sleeves?
Old 07-11-2017, 11:30 PM   #6
Chevy Fleetside
look at the 3rd picture down. The only problem I had with the sleeves, is they are backwards. I had to use the outer tie rod ends because they were threaded that way, but they still work.
Old 07-12-2017, 12:02 AM   #7
Captainfab
60-66 Nut
If you just change the entire steering linkage, you don't have to worry about those. The only thing about swapping the steering linkage is you will need to drill 2 holes to mount the newer idler arm. The one plus is that all your steering, ball joints and brakes will be from the same year truck. Much easier to remember when you need replacement parts.
Old 07-14-2017, 10:50 AM   #8
Bagged1972
Captain fan I sent you a PM about one of those clutch master cylinder brackets.
Old 07-15-2017, 12:48 AM   #9
Captainfab
60-66 Nut
I replied to your PM.......
