Old 10-24-2003, 03:02 PM   #1
71-longbed
Its Magically Delicious
71-longbed's Avatar
rubber fuel lines
what size hose is it ??? and how much gas is usually left in the tank when your gauge reads empty ???
the hose i have on there right now definately looks 30 years old and i dont trust it
any tips or suggestion from people who have done this before would be sweet
thanks
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 10-24-2003, 06:09 PM   #2
john
member #16
john's Avatar
The fuel line will be 5/16" or 3/8" depending on the engine size original to your truck. Measure steel tube. If you disconnect your line at the top of the tank first you will lose very little fuel changing the hoses.
john is offline   Reply With Quote
Old 10-25-2003, 12:38 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
only way to tell at what point your tank is empty, it to run out of gas.
I do this on all old vehicles within a week of buying them...just toss a 5 gallon can in the bed when you see that you're getting low.
And don't forget to fill that can up.
If your truck came with an inline or a 2 bbl small block, then you should have 5/16 fuel line.
If you had a 4 bbl small block, or a big block, then you should have a 3/8 inch fuel line.
Old 11-08-2003, 05:19 PM   #4
71-longbed
71-longbed's Avatar
john ... what do you mean " by disconnect the line at the top of the tank" .... the one right by the gas cap?? ... or the vent on the passenger side ??
i would think it would pour out just the same ... am i wrong
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Old 11-08-2003, 08:56 PM   #5
john
member #16
john's Avatar
If you disconnect the main fuel line that is screwed into the sending unit ,that will not let fuel syphon through the line. John
