07-10-2017, 05:51 PM | #1 |
Need Picture of 66' Big Back Window Shoulder Belt
Need picture(s) of where factory shoulder belt fastens in a 66 big back window cab.
Thanks, Les |
07-10-2017, 06:08 PM | #2 |
Moderator
Re: Need Picture of 66' Big Back Window Shoulder Belt
"Factory" shoulder belts . . . http://67-72chevytrucks.com/vboard/s...d.php?t=522706
Anyway, here is some info that might be helpful - http://67-72chevytrucks.com/vboard/s...d.php?t=679368
07-10-2017, 07:30 PM | #3 |
Thanks for info, very helful.
Would still like picture of 66 with big back window and factory shoulder harness Need the piller area. Thanks, Les |
07-11-2017, 11:20 AM | #4 |
Here's a couple with the Juliano's belts......
07-11-2017, 01:51 PM | #5 |
TF
Thanks for photos of big back window with should belts, very nice interior. Is yours newer belts in original factory bolt location? Thanks, big help, Les |
07-11-2017, 09:51 PM | #6 |
I used the factory holes in the floorpan but the sidewall anchor holes were non-existent so I had to make those.
07-11-2017, 11:16 PM | #7 |
I too use Juliano's belts and backing plates and drilled my own holes. The only thing I can offer to the o.p is take the time to fit your belts to YOUR liking. Factory holes are a one size fits all generic deal. If you sit in your seat and have a helper hold the belt mount in various locations you will find the spot that best fits your stature. Then do the same on the passenger's side with your regular shotgun rider in the seat.
07-11-2017, 11:43 PM | #8 |
Thanks for how you did your installations.
Les |
