A/C question for 1987 Chevrolet Silverado R10
I just dropped a reman 350 on my 1987 Chevrolet Silverado R10. I installed a new AC compressor, accumulator, and condenser. I'm trying to find out how much freon and oil is used for my truck. Also what type of oil?I will be using r134. Any help is greatly appreciated.
Re: A/C question for 1987 Chevrolet Silverado R10
Help anybody, got a 86 gmc 1ton dually, developed a ac blower problem, won't blow on 1 low or 2med or high when switched on will blow on high if you thump the relay but when you drop back to med position it quits blowing again, back to high rethump the relay and blows again on high i have replaced blower motor, relay, resistor and cleaned and relocate ground no change in problem anybody have any idea whats wrong with this boat anchor
#3 | |
![]() Join Date: Jun 2016
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 Last edited by DieselSJ; 07-14-2017 at 11:14 AM. |
Add PAG 100 oil in quantities as below and close the system up.
•Compressor- (1 ounce) •Evaporator - (3 ounces) •Condenser - (1 ounce) •Accumulator (2 ounces) As DieselSJ suggests: When an R-12 system is retrofitted to 134a, the general rule of thumb is that the refrigerant capacity/charge should be reduced to 80-90 % of the original capacity. The original GM spec for these trucks was 56 ounces of R-12. So, if we take 56 ounces of R-12 and multiply it by .85, we get a 134a charge of 48 ounces. |
40.5 oz is what I used 4 oz of oil and 18 oz & 2 12 oz r-134 cans plus a little left over in one to see the sweat on the metal part of the hoses.......the 18 oz freon can i used had oil in the mix......
http://i204.photobucket.com/albums/b...baae5d9a7e.jpg |
#6 | |
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
