Old 07-11-2017, 01:51 PM   #1
bhayes1
bhayes1's Avatar
P0300 code
During a family road trip my check engine light came on so I ran the code and it came back as P0300 random misfire. I filled up at a shady place so I figured maybe I got some water in my tank. Ran a can of sea foam through it and it cleared it but came back shortly after.
Truck couldn't possibly be running any better. No missing, sputtering etc.
From what I read this code is hard to diagnose because it doesn't give you a specific cylinder as a starting point. I hate to just start throwing parts at a truck that runs so good. Anyone have any tips....
1969 GMC K2500
bhayes1 is offline   Reply With Quote
Old 07-11-2017, 05:15 PM   #2
Hidesertchevy
Re: P0300 code
Plugs and wires is what I would start with
Hidesertchevy is offline   Reply With Quote
Old 07-11-2017, 08:58 PM   #3
bhayes1
bhayes1's Avatar
Re: P0300 code
That's what I'm leaning toward.
1969 GMC K2500
Old 07-12-2017, 07:15 AM   #4
Country Suburban 4x4
Country Suburban 4x4's Avatar
Re: P0300 code
How many miles are on your truck? And does the engine actually feel like it is misfiring? Or does it still run smooth? The 99-06 trucks have been known to throw the po300 after 120,000+ miles because the timing components wear, but the crankshaft position sensor still reads to the factory specs. This causes it to think there is a misfire under long driving times, or under heavy load. I went through this with my Silverado. The engine runs amazing at 170k miles with no sign of misfire. I'm not saying that this is definitely your issue, plugs and wires wouldn't hurt. But if it is the same issue, you'll have to go in with a scan tool and do a re-learn on your crankshaft position sensor. Hope this helps.
'83 GMC K2500 Suburban 4x4
2000 Chevrolet Silverado 1500 Z71 4x4
God Bless America!!!!
Country Suburban 4x4 is offline   Reply With Quote
Old 07-12-2017, 10:18 AM   #5
bhayes1
bhayes1's Avatar
Re: P0300 code
Never heard of this, but this sounds exactly like what I have going on. Truck is a 2011 with a 5.3
The light just went back out since I got back home yesterday and did some in-town driving. I'll have to do a little research on the re-learn and see what I come up with.
1969 GMC K2500
Old 07-12-2017, 10:28 AM   #6
jjzepplin
jjzepplin's Avatar
Re: P0300 code
I just bought this cool little gadget made by Foseal on Amazon. It plugs into your obd2 plug and you use your phone to read the codes and clear them as well. A little research on Youtube and I found the leaking vacuum hose.
Not sure about your issue but I like this little thing and it cost about $17.99.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 07-12-2017, 10:41 AM   #7
Re: P0300 code
Another thing I've run into with that po300 was the 15A fuse that powered my two upstream O2 sensors, it was blown and once I replaced it, my O2 code and misfire code was gone and hasn't come back. It's amazing what can cause issues in these computerized and electronic components.
