10-24-2003, 04:16 PM | #1 |
Air Suspension Components?????
I am trying to learn what I need to do air bags on my 72.
I know that I am going to get Firestone 2600 on all 4 corners Either (2) 3 gallon tanks or (1) 6 gallon tank Was told 3/8 fittings York Engine Compressor Digital air guage Brackets Brackets - would like to make my own, need drawings of them with some sizes specs. Now I dont know what else I need Can someone please tell me what I would need to get it all to work together.
1972 Chevy C-10 Short Stepside 6Cyl, 3 spd, not opts (Current Project) Now a 2004 SSR 5.3L with 4L60E Now Ididit tilt- ps, pb 2002 Saturn L200 2006 Toyota Highlander HYBRID |
10-24-2003, 05:52 PM | #2 |
Happy to be here
I'm no expert, but I do have some suggestions. Since you are considering two tanks, I would go with two 5 gallon tanks. I suggest this, because I think anything less and you won't have enough volume to raise your truck more than once without your system having to cycle. York Engine Compressor The York compressor was used as a were factory a/c compressor on cars for years. It's an excellent unit, but not very pretty under the hood. They will pump more pressure in your tanks faster than just about any 12 volt compressor will. The only down side I know of is the engine has to be running for them to work. 3/8 fittings 3/8" fittings (and line) are fine if you just want your system to flow well, and they are reasonable in price. If you want to clown a little, then a 1/2" system will move air much faster. Digital air guage You can use two dual needle analog gauges just as well. The digital gauge is nice because they are easy to read. They also allow you to fine tune your air pressure with a bit more accuracy. You are going to need 2 or 4 switches, wiring harness, or wire to make one. You will need a bunch of line clamps to secure the air line, and some rubber grommets to put in holes where the air line passes through metal. I'm sure I have left a couple of things out, but this will get you started. Go to Air Ride Technology and look at their kits. Even if you don't buy anything from them, you will learn a lot looking at the site....
10-24-2003, 06:19 PM | #3 |
chevelito
all good points.
I would do independent fronts and T the back as a minimum to reduce body roll. If the fronts are T'd together, the air will flow from one bag to the other during cornering, increasing the roll of the body. The digital guages are nice, but I dont see the point of pinpoint accuracy. If you run 1/2" lines, it is soo quick that a quick push of the button will get you at a height you dont really have control over. (unless you run a two port bag with the other port connected to a smaller solenoid to make it go down slower). Brackets: You dont need brackets for the rear. Just open up the original hole in the frame for the coil spring to make room for the port, then drill 2 mounting holes in the frame next to the hole. For the fronts, you can fab your own or see NSANE68 who sells the brackets itself. I agree with more air reserve the better.
New deadline...when my son can drive. Aloha from Honolulu, HI |
10-24-2003, 10:58 PM | #4 | |
My Thoughts Exactly!
10-25-2003, 07:25 PM | #5 |
Thanks for your suggestions. I am not sure how soon I am going to do this, but looking for all the information that I can so I can do it myself.
Thanks Again Jerr
10-26-2003, 12:46 AM | #6 | |
Happy to be here
It's just my opinion, but the York compressor is a clunky looking box. Paint it, polish it, what ever you want, but it still looks like a clunky box to me. |
10-26-2003, 12:54 AM | #7 | |
10-26-2003, 02:48 PM | #8 |
Nothing clever
York
Anyone know what model number for the York? also if anyone knows where to get one other than the Treasure yard.
Got "the Midas Touch!" |
10-26-2003, 02:50 PM | #9 |
for the most bang for the buck you should look for the 210L or 210R.
I got mine off of a freightliner semi. www.onboardair.com sells new units. |
10-26-2003, 07:32 PM | #10 |
If you want to get one from a bone yard, you can find them in old VOLVO'S and JEEP WANGONEERS. Both around the 70's
10-27-2003, 12:49 AM | #11 |
Progress = 0%
I got mine off a mid to late 70's Mustang and it ended up being the high output 210 model. I just saw 2 of them today at the salvage yard on 70's Ford trucks.
Here is a link with some good info on the Yorks. It tells how to identify which model it is by looking at the shape of the end of the output shaft. http://www.coloradok5.com/york.shtml
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
10-27-2003, 10:17 AM | #12 | |
Trucker.
10-27-2003, 04:06 PM | #13 |
Nothing clever
wanna part with it??
10-27-2003, 04:36 PM | #14 | |
Trucker.
10-28-2003, 07:31 AM | #15 |
FORSALE
check out www.onboardair.com this is where i got all the stuff for my jeep wrangler. i dont know about 'bags but it will air up one 33x12.50x15 tire from flat to 30psi in 30 seconds. it will even set the bead. i am running a 3gal tank
1967 chevy 1/2 ton short step |
10-29-2003, 12:09 AM | #16 |
I am very curious about this too. I am thinking of bagging my truck, but am new to airbags. Does anyone sell a complete kit specifically for our trucks that is reasonably priced?
'72 Chevy Custom/10 Shortbed '77 2wd K5 “Halfbaked” '93 Indy pace truck ‘70 GMC Jimmy ‘76 K5 Blazer Follow me on instagram @C10squared |
10-29-2003, 12:40 AM | #17 |
chevelito
cheaper if you piece it together. check with NSANE 68 or ...damn, i cant remember his handle. it will come
11-30-2003, 08:20 PM | #18 |
im a little confused about this air ride set up as well. this tri-4 link, is this neccessary for a 67-72? also, 2.5 drop spindles up front, the rear needs the c-notch. then what? whats the range of height were talking at that point? i dont want it in the weeds really, not while driving at least. maybe 4/6 drop max? hard to say as theres not alot of pics of stepsides out there. better off going with static drop?
12-08-2003, 09:05 PM | #19 |
I am also new to this. How much does it cost for all of the parts and how hard is it to do.
