07-11-2017, 10:31 PM | #1 |
BMW & ASE Master Certified
Homemade push lock / socketless hose tool
Not many pictures of tools other than 250$ professional tool to install hose ends. This works for my hose and fittings.
Hose - aeroquip -6 socketless Fittings - summit racing twist-tite Harbor freight clamp 1 to 1.5" pipe PVC tube, 2 thread caps - for 90* and 45* 14mm socket - for the strait ones 2x4 5/8 drill bit (-6 hose size) Screws The hose clamp was just a scrap piece of 2x4. Drilled a 5/8 hole length wise. Then i cut the wood length wise in the center so now the wood can be squeezed the hose. Last part is to get a chissle and force the block of wood to split apart so you can remove the holder once 2 fittings are installed. 2 screws on each end. Will be making a new one to incorporate wood tee nuts and 1/4 bolts so the wood doesn't get stripped from the smaller wood screws. Pretty self explanatory on how it works and how to build one. It can be made stronger by not welding the tube to the harbor freight clamp material and just making some flat bars connect the tube to the rail. Or by using a pipe clamp setup... even more heavy duty The clamp swivel part fits perfectly in the pvc cap. Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress Last edited by 87chevy.com; 07-11-2017 at 10:52 PM. |
