Old 07-12-2017, 05:32 AM   #1
msgtmac
Timing cover
I am rebuilding my 250 and found the timing cover damaged. Probably did it myself pulling the harmonic balancer. I am having a hard time finding one. Do all the 60 series L6 use the same cover? Thanks for the help.
msgtmac is offline   Reply With Quote
Old 07-12-2017, 09:49 AM   #2
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: Timing cover
The 194-230-250-292's use the same cover.
235's and 261's use a different cover.
http://www.ebay.com/itm/ONE-1-194-23...JZWB3J&vxp=mtr
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 07-12-2017, 11:45 PM   #3
Captainfab
60-66 Nut
Re: Timing cover
I can likely fix you up with one if the one on ebay doesn't work out for you.
Old 07-13-2017, 05:45 AM   #4
msgtmac
Re: Timing cover
Thanks you guys. I did buy the Ebay cover and will let you know, Captain if it doesn't work.
