Best way to remove original rubber brake lines from back of hubs?
I blew a rear rubber brake hose on my '68. The ones that come off of your hub. Mine are pretty rusted. I have a set of line wrenched. I believe the fitting to be a 5/8". Is it best to saturate them in something Like PB Blaster, some kind of penatrating oil for a few days? I tried to brake one end loose, very gently, and I stopped, as it didn't feel good. If anyone has had any exwwith this time of situationfeel free to chime in please!
Re: Best way to remove original rubber brake lines from back of hubs?
I cut mine and slid a box end wrench over the line to get it off.
That is a good idea. Use a 6 point! I recently had the same problem but did not go at it with enough patience. One thing lead to another and I eventually found myself replacing the entire set of brake lines!
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
laying low
![]() Join Date: Mar 2001
Certainly soaking them in some kind of penetrant will help. Bump them a little back and forth and soak them some more can help.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
If the fitting gets stripped with the box-end wrench, you can always pull out the trusty vise grips. You are not reusing the line/fitting, so no need to keep it pretty.
![]() Join Date: Aug 2004
A deep socket will work too, preferably a 6 point
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
What size are the fittings, 5/8's???
Well, I just twisted the hard line thats on the back of the rubber line. Looks like I'll be replacing that whole line now. Lucky me....
Moderator
![]() Join Date: Jun 2017
Before you order new hard lines...make sure the bleed nipples in your wheel cylinders are able to be opened so you can bleed the brakes...
I am a bit OCD on brakes...if it was mine I would pull the rear drums, then replace the rear brake shoes, cylinders and hard lines...plus the flex line... Little trick I learned a ling time ago...especially with old brake lines...tighten the nipple on the pipe first, then back it off using lots of spray like WD-40. Check out LMC link : There are several different cylinders,,,makes sure you get the right ones... http://www.lmctruck.com/icatalog/cb/full.aspx?Page=144 ![]() ![]() ![]() |
