Learning, question on body lines
Yes, I've used the search tool, but just want to see if I'm on the right track.
Been looking at trucks, and reading up on body lines/alignment with cab bushings, spacers, etc. This is a Texas born truck, so rust is at a minimum, but as you can see form the pics, it appears to me that the drivers corner of the cab sits way low compared to the bed. The passenger side appears to be good, and the bed appears to be level (notice the downward slope with the rear picture) I assume, and again just based off of photos, that this would likely be a worn out cab bushing, or potentially a rotted cab mount on that side? When I read the forum, guys are talking about, 1/8, 1/4, 1/2 inch gaps....this looks like a good 1-1 1/2 inches. Thanks for any input ![]() ![]() |
#2 | |
Posted via Mobile Device |
Re: Learning, question on body lines
Post picture of those cab mounts.
bed almost looks twisted.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
![]() Join Date: Jul 2016
That cab mount is a 5/8 head bolt with a captured nut under the gas tank, jack the cab up take the bolt out and check the cab mount and the condition of the cab support, very simple job.
