Old 07-13-2017, 03:34 PM   #1
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Question Freon Capacity?
Searching has turned up nothing so far but I'll keep looking. In the meantime, does anyone know the original factory A/C system capacity for my '72 K20 with 350 engine?
I thought there was a sticker under the hood but now I can't find it. Thanks!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 07-13-2017, 04:05 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Freon Capacity?
Most I've seen had 3.75# on the sticker on the compressor. However, my 69 originally had a sticker over the 3.75# that said 3.25# R-12.
FirstOwner69 is offline   Reply With Quote
Old 07-13-2017, 04:13 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Re: Freon Capacity?
3.75 lbs of freon, 10 ozs of oil.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 07-13-2017, 04:43 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Thumbs up Re: Freon Capacity?
Thank you, gentlemen!
- Mike -
RIP El Jay
Old 07-13-2017, 08:05 PM   #5
Sweeet67
Re: Freon Capacity?
10 oz of oil in the low side port?
Sweeet67 is offline   Reply With Quote
Old 07-13-2017, 08:06 PM   #6
Sweeet67
Re: Freon Capacity?
Also, I have the original a6 compressor, does it cycle or run all the time?
Old 07-13-2017, 08:35 PM   #7
jeffahart
jeffahart's Avatar
Re: Freon Capacity?
There is a procedure in the manual for compressor oil called "Checking the compressor oil". You can do that if you are swapping out to determine how much oil. Refrigerant capacity is not the same for r134 either. I just put in 7oz the a6 came with 3oz. I didn't hassle with the procedure in the manual. I probably have too much oil. But the manual lays it out pretty good.
White K20
jeffahart is offline   Reply With Quote
