Old 07-13-2017, 09:03 PM   #1
ApacheIvan
ApacheIvan's Avatar
Is this backwards?
Heater valve, I have seen this both ways, does it matter and is it backwards?
Dale - ApacheIvan
1972 Chevy Custom/20 Custom Camper Highlander
http://67-72chevytrucks.com/vboard/s...d.php?t=740479
Original Owner
** Do you have a 1972 Plaid Pickup?**
ApacheIvan is offline   Reply With Quote
Old 07-13-2017, 09:33 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Is this backwards?
That is mounted correctly, though it actually shouldn't matter. It opens / closes to control the flow of coolant. That said, coolant *might* flow better in one direction than in the other. But the pic shows the way they came from the factory.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 07-13-2017, 09:34 PM   #3
leddzepp
Moderator
leddzepp's Avatar
It's correct.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 07-13-2017, 10:19 PM   #4
Andy4639
Old member
Andy4639's Avatar
Talking Re: Is this backwards?
Doesn't really matter as long as it works.
I'd just about bet money the factory didn't care which way they where mounted back then.
They where installed by a human and we all know humans make mistakes.So to say one way is correct and the other isn't is not really relivant.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 07-13-2017, 10:37 PM   #5
kwmech
I must have the "Rare" factory backwards mounted valve with the corvettte 327 option. Must've been installed on a Monday. Sarcasm over.....
