07-14-2017, 02:16 AM | #1 |
air line
where did you guys run your air line for your air ride? any pics or diagrams would be helpful. im running a full manual air ride set up
07-14-2017, 06:40 AM | #2 |
Re: air line
I got all mine from my local Parker store. They had a very good selection of dot line and fittings.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
07-14-2017, 08:31 AM | #3 | |
Re: air line
In regards to heat sources; place your hand around the line and if your hand is close enough to something that may burn you, you need to move the line. I hope this helps. Feel free to give me a shout directly if you need anything else.
John J. Sales/Tech Direct Line: 812-481-4737 Office: 812-482-2932 JJohnson@ridetech.com Instagram: @ridetech_john |
07-17-2017, 07:31 AM | #4 | |
Re: air line
If reality forces no other options, slip some rubber hose over the airline & then some sort of heat shielding on top of that. Also, any place that the airline can contact metal, slip some rubber hose over it. Cheap insurance.
