Old 07-14-2017, 10:02 AM   #1
CG
BlahBlahBlah
Dead battery ignition switch question
Ok before I panic and have to delve into wiring grounding issues ... We put a new full rubber floor mat in my K20, used to just be a steel floor with a couple of mats tossed on top.
There are several extra wires that have been sort of just out there in the wind, so to speak lol, that are now covered by the mat.
My nephew parked it in the garage for me and when I went to start it up nothing happens, really dead. One thing I noticed is that the ignition was on accessory when I put the key in. I had no idea you could pull the key on accessory mode. Could the fact it sat on accessory for a week have caused the draw? Or do I need to pull the mat and double check the wires that were once loose but now made stationary due to the mat holding them down?
Last edited by CG; 07-14-2017 at 10:37 AM. Reason: I need to go back to Mavis Beacon typing class
Old 07-14-2017, 10:28 AM   #2
Big Block
Big Block
Big Block's Avatar
Re: Dead battery ignition switch question
Could have a wire that is a 12 volt supply wire that caused the battery to drain when the key was left on. It would be a direct short. Make sure you don't have any bare wires in contact with any metal. Good luck.
Big Block is offline   Reply With Quote
Old 07-14-2017, 10:40 AM   #3
CG
BlahBlahBlah
I planned on driving the heck out of it over the next week. Now Im not so sure and working on truck gremlins is not on my to do list haha. Its on the charger now.
Old 07-14-2017, 11:38 AM   #4
HO455
Post Whore
HO455's Avatar
Been there. Done that more than twice. I do the "check the key position when I shut it down" routine nowdays.
RIP Bob Parks.
Old 07-14-2017, 03:34 PM   #5
CG
BlahBlahBlah
Charged it up, let it run for awhile. Been running around doing my errands close to home first, no problems...Whew!
