68 4x4 3/4 ton
I have a 68 3/4 4x4 and a 87 one ton 4x4, going to swap the axel's, will the springs bolt up to the 68 from the 87? I have some 4 in lift springs from an 84 but the 68 rears are proving hard to find so was going to use the one ton rears. Will it work?
![]() Join Date: Mar 2003
Re: 68 4x4 3/4 ton
Fronts will not work, the square body springs are longer. Tape measure needed for the rear.
Re: 68 4x4 3/4 ton
I put 84 4x4 running gear under my 72 frame rear I had to resend the spring perches and shock mounts. Springs bolted right in.Fronts needed a lot of cutting drilling and bolting but everything turned out perfect.
1972 Cheyenne Longhorn k20, 402, A/C |
