Old 07-15-2017, 02:05 PM   #1
jbgroby
jbgroby's Avatar
Chasing an electrical gremlin
I hope i explain this correctly and also hope other can direct me to the possible fix?
When I pull the headlight switch out to the first position the hood running light and tail lights come on. When I press the brake pedal the passenger side brightens but NOT the drivers side.
BUT when I pull the switch to out fully to turn on the head lights, the tail light out out?
Any pointers?
21 circuit from E-Z wiring is what is installed
jbgroby is offline   Reply With Quote
Old 07-15-2017, 02:49 PM   #2
bpmcgee
bpmcgee's Avatar
Re: Chasing an electrical gremlin
I believe the tail light is a two filament bulb -- one being running light and one being brakes. If the drivers side doesn't brighten, it would mean either the filament is bad or there's a bad wire going to that particular filament.
I BELIEVE the front parking lights are supposed to go out when you turn on the headlights -- is it possible you got the front and back parking lights reversed?
B
bpmcgee is offline   Reply With Quote
Old 07-15-2017, 06:51 PM   #3
jbgroby
jbgroby's Avatar
The hood lights go out when the headlight come on as they should, no matter the position of the switch, I still have power to the brake switch when I press the brake as I should as well. The dash and front end works as they should, its the brake lights that are making me crazy.
Old 07-15-2017, 10:05 PM   #4
goofy063
check your
rear bulb I've seen the filaments burn through and fall across to the other filament and back feed
goofy063 is offline   Reply With Quote
Old 07-16-2017, 09:07 PM   #5
jbgroby
jbgroby's Avatar
I'll buy two new bulbs and give it a try. Thanks
