Old 07-17-2017, 04:41 PM   #1
loujizzel
Help me! Please
Okay I have a 73 C10 square body short bed when I purchased it it was already lowered it has Western chassis 2.5 inch drop spindles up front and the flip kit in the rear and it's down about maybe 6 or 7 inches in the rear the front was slightly higher than the rear when I looked at the springs they had spring spacers in the springs one of them or two of them were heated really poor wor.... so what I did was I ordered a set of 3 inch drop Springs and a brand new set of nitro drop shocks for the front I had the upper and lower control arm poly bushed with energy suspension bushings I just had it all installed and now the front is sitting even higher than it was before granted the springs that it had were warned and not stiff the new front Springs are definitely stiff and I know they need to settle but it is sitting way too high what could be the problem? If my math is right with a 3 inch drop spring and a 2.5 drop spindle I should be down five and a half inches I'm nowhere near that..... any ideas why I'm not low upfront the only thing I could think of is the bushings are super tight since they're polyurethane or they put the spring on upside down I have no idea I'm just grasping for straws I want to and I guess the only other alternative is to actually cut the spring not what I want to do
loujizzel is offline   Reply With Quote
