Old 07-17-2017, 09:14 PM   #1
Leonard1
Leonard1's Avatar
Check out this trim
Original trim, original cab corner. It looks worse in person than in the picture. I guess I need to waller (if that's a word) the hole out?
Leonard1 is offline   Reply With Quote
Old 07-17-2017, 09:34 PM   #2
Joesjunk
Joesjunk's Avatar
Re: Check out this trim
I have an all original 71 Cheyenne built at Janesville and the trim is put on terrible! Janesville trucks seem to be built very sloppy
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is online now   Reply With Quote
Old 07-17-2017, 09:51 PM   #3
Baker72chevy
Started putting my trim on
Baker72chevy is offline   Reply With Quote
Old 07-18-2017, 12:06 AM   #4
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
From what I see Leonard, your door to bed molding is dead-on. Don't often see that on less than a rebuild, I take it the cab mounts were replaced?
Not to hijack this thread, but if anyone has precise measurements for each end of each piece, that would be very much appreciated. One side only of course, but tail would be a bonus. I can get by with the horizontal measurements only (e.g., front edge of door to hole is........). The height seems pretty straight forward, even without GMs reference points.
GM provides the measurements, but the reference points are a mystery. The truck I'm building never had the moldings, but will.
On a side, GMs assembly manual is more or less a guide. First, there's no substitute for a good eye test. That's the obvious............. Second, with at least some of the factory hardware packages that came with the moldings, they used a lot of 3M stick-on clips. In other terms, you don't have to drill so many holes. Seems I read this change occurred 71-72. That said, wouldn't surprise me if the difference is "replacement parts", sometime after 1972.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-18-2017, 10:01 PM   #5
Leonard1
Leonard1's Avatar
Hey Baker, that looks awesome! New trim?
71short: Yes, new mounts. I would have gladly taken measurements for you before I put the trim on.
Old 07-18-2017, 10:24 PM   #6
Baker72chevy
We did all the body work then put
The truck back together then line the trim up
Then took it all back part painted it then
Back together then new trim
Old 07-25-2017, 02:23 AM   #7
71CHEVYSHORTBED402
Sounds like a plan to me.
Tony
Old 07-25-2017, 11:35 AM   #8
NGN
NGN's Avatar
Just throwing this out I really don't know anything about trim, but could it be on the wrong side, is it possible ?
NGN is offline   Reply With Quote
Old 07-25-2017, 02:37 PM   #9
Leonard1
Leonard1's Avatar
That's the first thing I thought, but I marked it on the back when it was removed, and the profile of the top and bottom of the trim is different...
Old 07-25-2017, 05:03 PM   #10
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Instead of wallering out a hole, you can measure how far it's off. Remove the trim clip and remove the stud from the clip. Much like removing a rivet. Then cut a bolt to the length you need and drill a new hole in the trim clip, stick the bolt through so it's flush with the back of the clip and tack it. You technically wouldn't have to drill a hole in the clip. You could just place the stud where you want it and weld it on the clip.
This will relocate the trim piece without modifying your sheet metal. Or, you could get 2 plastic stick on clips and put the trim piece right where you need it. The stick on ones leave a lot to be desired over time though...
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
