Old 07-17-2017, 09:16 PM   #1
willy12844
rear end
I have a 72 c-10 and would like to know what the rear end ratio is, there is no tag. I know there are other ways of figuring it out but don't know what they are. Any instructions or methods will be greatly appreciated.
bill
The pessimist is one who feels bad when he feels good for,
fear he'll feel worse when he feels better
willy12844 is offline   Reply With Quote
Old 07-17-2017, 09:33 PM   #2
bill3rail
bill3rail's Avatar
Re: rear end
Search the site first,
http://67-72chevytrucks.com/vboard/s...d.php?t=578793
http://67-72chevytrucks.com/vboard/s...d.php?t=455117
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 07-17-2017, 09:34 PM   #3
bigrigpardo
Re: rear end
Pop off the cover count the teeth on the ring gear the look in and count the teeth on the pinion divide ring by pinion and that's your gear ratio. That's the definitive way to be absolutely sure.
bigrigpardo is offline   Reply With Quote
Old 07-17-2017, 09:35 PM   #4
bill3rail
bill3rail's Avatar
Re: rear end
Courtesy of LocDoc...
Rear Axle Ratios
Ratio 2.56:1 - Tooth Combination 41,16
Ratio 2.73:1 - Tooth Combination 41,15
Ratio 3.07:1 - Tooth Combination 43,14
Ratio 3.08:1 - Tooth Combination 40,13
Ratio 3.08:1 - Tooth Combination 37,12
Ratio 3.31:1 - Tooth Combination 43,13
Ratio 3.36:1 - Tooth Combination 37,11
Ratio 3.42:1 - Tooth Combination 41,12
Ratio 3.55:1 - Tooth Combination 39,11
Ratio 3.73:1 - Tooth Combination 41,11
Ratio 4.10:1 - Tooth Combination 41,10
Ratio 4.11:1 - Tooth Combination 37,9
The tooth combination numbers will be found stamped into the ring gear when you take the back cover off.
They may not all be for the trucks.
Old 07-17-2017, 09:41 PM   #5
s10mk
Re: rear end
If nothing else, you can pull the cover off and look at the ring gear. The number of ringer gear and pinion teeth is usually stamped onto the outside of the ring gear. Example, "41-10", which is a 4.10. Or if it isn't marked like that, just count the number of ring gear teeth and divide by pinion teeth.
s10mk is offline   Reply With Quote
