Old 07-18-2017, 02:13 PM   #1
Harrison.
What size hardline for disc brakes up front?
I've done a little digging and have read that drum brake trucks have 1/4" line all around and disc brake trucks have 3/16" line up front and 1/4" out back. My truck is a 70 model that someone has put discs on up front but front lines go through a tee fitting from the MC to 3/16" line and then use adapters on the hoses to go from 7/16-24 flare fitting (for 1/4" tube) to a 3/8-24 (for 3/16" tube). I'm about to re-build my brake lines and trying to figure out which I should be using?
http://harrisonspeed.com
Instagram: harrisonspeed
Harrison. is offline   Reply With Quote
Old 07-18-2017, 02:16 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: What size hardline for disc brakes up front?
I always use 3/16" hard line for disc brakes.
Keith
Convert to disc brakes.
Old 07-18-2017, 02:24 PM   #3
davepl
davepl's Avatar
My thinking is for the front circuit each side has it's own line, so smaller 3/16" is OK. The rear shares a line, so gets larger 1/4" until the tee.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-18-2017, 03:25 PM   #4
67 chevelle
67 chevelle's Avatar
Ive done several disc retrofits , and what the factory had for drums , worked fine for discs
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 07-18-2017, 03:59 PM   #5
lolife99
lolife99's Avatar
And I've run 3/16" hardline to the rear for drum brakes without issue.
Keith
Old 07-18-2017, 06:54 PM   #6
Harrison.
Thanks guys! I ended up making them out of 3/16" because it's what I had on hand and using the adapters for the hoses, I was just confused why there were adapters at all in there.
