![]() Join Date: May 2010
Horn button gasket
Does any of our vendors sell these? GMCPauls or anyone? I'm looking for the gasket that wedges underneath horn button and the factory wheel.
Thanks |
The Older Generation
Re: Horn button gasket
I'm thinking you mean the horn button retainer. There is no gasket. A little more information would help as to what year of truck. '67 & '68 are the only two years that used the rubber horn cap retainer. The '69-'72 horn cap had the retainer clips built in to the cap. Here is the rubber retainer for the '67 & '68. http://www.classicparts.com/1960-68-.../#.WW54jN3VqAg LockDoc
I have a 72. Underneath the center horn is a black gasket foam that is like a cushion or gasket. It's from fitting as well.
#4 | |
LockDoc
Here you go.
Thanks. I will have to look at the ones I have to see if any of them have that. If a guy had some thin foam sheet it shouldn't be to hard to make. I have never see one in any of the parts catalogs.
LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 07-19-2017 at 10:38 AM. |
My thinking as well lockdoc.
Might just buy some foam and trace it out. |
#8 | |
LockDoc
Wow. All six??? Quite the collection
![]() ![]() Thank you sir! |
Carpe manana
![]() ![]() Join Date: Dec 2010
I've been wondering about these gaskets as to whether or not these are OEM. I believe LMC has these listed, I know I purchased an aftermarket example several years ago. Here's one that was in place when I removed the steering wheel from a blazer I'm currently restoring: it's basically a survivor truck that wasn't altered save for a repaint and set of headers.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Ahhh.. Yep thats the one! I havent found that in the LMC catalogue. I will check their site
But as you said, I wonder if this was factory. I will also check in the build install pdf from the factory to see if anything is in there. |
Sure enough. Page 692 seal-horn button cap CA-KA105 Granted that is for a 69 wheel. I didnt find anything on the 70-72 models in the book. But it looks like they were in there at one point in time
#13 |
Carpe manana
Huh - just to clarify, the GM assembly manual shows a horn button gasket?
#14 |
#15 |
Carpe manana
Learning new things - love it. Thanks for posting.
#16 | |
Only $1.95 at LMC. |
#17 |
Carpe manana
Take it back to the dealer and demand one!
![]() My 72 k1500 doesn't have one and it too is unmolested.
#18 |
My 72 didn't have one. Interesting.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
#19 |
Carpe manana
Not present on the wheel I removed and kept from a 40k mile 72 Fremont built Super dually RV.
#20 |
