![]() Join Date: Nov 2011
Adjusting stock POA for r134
I have all new AC in my 72. Everything is new except for evaporator and POA. New compressor, new hoses, new evaporator and expansion valve. When I bought the new hose with muffler on it I opted to go r134 so it has the proper valve in it already, converted the valve on the POA. With that said, I had it professionally charged. I was told since everything was stock that I should have had my POA pressure adjusted to get optimum cooling. Now that it all works, it blows cool but nor really cold. I hate that I have to evacuate the system again and take the POA out. Vintage Air is telling me I should get the kit that eliminates the POA and cycles the compressor. I don't like that idea, I would like it to look as stock as possible. Someone told me there was a guy on the forums that will service the POA for me but could not recall who it was. I did some searches but could not find him. If it is easy to do, I suppose I can do it myself, but don't have an air compressor at the moment.. so I am open to any and all suggestions.
Dale - ApacheIvan 1972 Chevy Custom/20 Custom Camper Highlander http://67-72chevytrucks.com/vboard/s...d.php?t=740479 Original Owner ** Do you have a 1972 Plaid Pickup?** |
Moderator
![]() Join Date: May 2007
Re: Adjusting stock POA for r134
Get rid of the 134 and go back to r-12. Your factory system will never function properly with r-134. I've gone through this many times....
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#3 | |
Going to R12 will be the best and freeze you out but I had a system in a Chevelle with 134 and an adjusted POA valve and it worked really well. I would say it was almost as good as my buddy's R12 system. For 134 to work well in an original system the POA needs to be adjusted, you need a A-10 compressor(A-6 will leak at the front seal) and a duel pass condenser.
I did not have the other two, only the POA and it was still good. Good luck. Last edited by ss454conv; 07-18-2017 at 10:17 PM. |
Old member
134-A will cool as good as any R-12 system ever would. If you do the system right and don't cut corners it will cool better. The POA valve may be the part that keeps the 134-A from cooling down and this is why they say replace it.
If it where me I would replace it and be done. If you keep it then go back to R-12. 134-A done right will cool as good are better than R-12! I have done my 71 C10, 64 SS Impala and the 56 Bel Air all in 134-A and it works great you just have to do it correctly. As far as looking correct well most people (generally speaking) have no idea what they are looking at under a hood of a vehicle most of the time. Lets see some tempatures of all these R-12 systems that are freezing cold guy's. ![]() My C10: The Impala: ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 07-19-2017 at 06:25 AM. |
You need to talk with F.A.A Benny. He is on the forum and can adjust your POA valve. As leddzepp said R12 is best but 134a will work with a lot of changes. A parallel flow condenser or at least one to two pusher fans on a standard condenser is required. I just rebuilt mine and have a pretty detailed thread on the subject. Andy above is also correct but notice all the changes he has made; he has installed a modern compressor, replaced his POA and expansion valve with an accumulator, pressure switch, and orifice tube and is running a parallel flow condenser.
1971 Longbed BB Cheyenne Super 1972 Longbed SB Cheyenne Super 1972 Longbed Highlander Custom Deluxe 1975 K5 4x4 full convertible Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165 Greg Smyrna TN |
#7 | |
F.A.A Benny is in TX, not sure which city. You can private message him and I'm sure he will respond. He restores AC systems for a lot of different vehicles. His work is top notch! Now that I went through your build thread, I completely understand why you want to keep it original. Keep it R12, just my .02 cents.
#9 | |
![]() Thanks again for taking the time and pointing me in the right direction.
#10 | |
Moderator
![]() Every time I post about r-12 being superior to r-134 in a FACTORY system he goes on about how it isn't...yet his system isn't factory anymore...which is my point! I have no doubt it works; it better after spending $1200 on the changes.
#11 | |
Old member
It is factory looking!
It was 134-A with all internals for a 71 when I did it the first time. It did fine but I knew it could do better and that's when I swapped everything out. Back when I did the AC the first time though nobody was doing the POA valves so it would cool but not like it does now. When I did do the swap it was easier to just swap it out for the newer stuff. Quote:
Unless you are going for 100 point show vehicle why worry what is factory are not, If you drive it like I do then comfort is what I go for. Here are a couple of pictures of the SS for you also. By the way the SS has the A-6 compressor in it. It runs fine so far but it just got charged up this past winter so time will tell. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#12 | |
Old member
![]() Quote:
#13 | |
It's entirely possible the PO made changes or adjustments to the POA valve, as it already had the 134 fittings when I got the truck. But it's stock pieces so far as I can tell, except the condenser as noted. Oh and I suppose I should admit that I changed the compressor later, but that was for a leak. So I'll go with "stock appearing" R-134 and you can be "actually stock" R-12. So I reject your theory! R-134 is the solution to every problem! With suitable disclaimers attached! That said, if I had a functioning R-12 system that I was sure wasn't going to leak that pricey stuff back out, I'd just stick with R-12 myself. But if I wasn't sure, I'd rather leak R-134 than R-12.
#14 |
PM ls1nova71 on here. He has 2 of these trucks that look dead stock and blow icebergs. I believe he uses the biggest parallel flow condenser he can get and switches to a squarebody unit in the cab box. IDK, i just know it works and how!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#15 |
Old member
My 64 SS Impala blows at 36* with a stock system. When I bought it the guy had done the 134-A swap but it wasn't working. I redid the lines and got it back in shape. It has been fine all summer so far.
I added the longer lines to hide them inside the fender and a new dryer. Vacuumed and charged it. As I have stated before if done right doesn't matter which Freon you use. Getting 40 year old fittings to seal off is the hardest part to do. ![]()
#16 |
Big Block
Ok guy's this is all new to me. Just bought a 71 Chevy Custom Deluxe Short Bed with factor air. It appears to be intact and complete. The previous owner did a new heater core. It has the original compressor on it but the system is empty and the compressor won't engage. I have a factory style replacement compressor. Should I replace the receiver, dryer, and compressor and pull a vacuum to see if it holds. If it does hold a charge, would you go ahead and charge it with r12. Or just replace everything first and upgrade everything to 134. The system hasn't worked for over 20 years.
#17 |
As long as were beating this to death! Whats the going rate for R12?....If you know somebody you might get a deal, 15 yrs ago local shop here was charging $400.00.to evacuate and charge.....I changed and charged my 93 over to 134a for $165.00 no regrets....I'm not the purest, I like the modern engine and 1 belt....If you like keeping it total stock, Excellent, its your boat.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
#18 |
Moderator
I can buy r12 on craigslist for LESS than r134 at autozone here, so the cost savings is a myth.
I really don't care what anyone does with their ac system, I post what works and I have cold air in ANY condition. If people want to run around the block 6 times chasing cold air, throwing money at what might work or work marginally, that's fine. I'll just hit the easy button and walk next door.
#19 |
I am going to leave it to Benny
#20 | |
![]() Join Date: Mar 2005
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
#21 |
I don't think anyone can beat Wal-Mart price on 134a.https://www.walmart.com/ip/Super-Tec...134a/617476716
#22 |
Moderator
R134 is $5 a can in Vegas, I buy a case every time I visit. I use 134 in all of my newer cars because that's what they are DESIGNED for and it works like it should.
#23 | |
#24 |
#25 |
Moderator
It's at least $10 a can here with a $10 deposit on each can on top of that. You get the deposit back only if you return the used can within 30 days. They also have a "new" style dispenser on them that is California only. This is why I have stockpiled both 12 and 134 for years now, it's only a matter of time before do it yourself AC will no longer be an option...then everyone will be forced to pay a fortune to have a shop do the work.
