Old 07-18-2017, 10:46 PM   #1
lswonmatt
66 driveshafts
So I thought for sure my 66 gmc long bed would habe a 2 piece drive shaft but today i was going to unbolt the bed to remove it to start the bodywork on cab corners and got to looking and it is a 1 piece drive shaft .... did long beds come with one piece drive shafts or has mine been swapped out sometime in its life i just thought it was odd I always hear about 2 piece shafts on long beds and find out mine has a 1 piece
lswonmatt is offline   Reply With Quote
Old 07-18-2017, 10:49 PM   #2
Cooper197
Cooper197's Avatar
Re: 66 driveshafts
I have a 66 Chev C20 long bed and it's a 2 pc driveshaft.
Cooper197 is offline   Reply With Quote
Old 07-18-2017, 11:20 PM   #3
DPowers
DPowers's Avatar
Re: 66 driveshafts
My 66 LWB is a two piece as well. Is there a place where a carrier bearing was at some point?
DPowers is offline   Reply With Quote
Old 07-19-2017, 12:12 AM   #4
Captainfab
60-66 Nut
Re: 66 driveshafts
I have seen 2 longbeds with a 1pc driveshaft from the factory. I really don't know what the deciding factor was.
Old 07-19-2017, 08:25 AM   #5
lswonmatt
Re: 66 driveshafts
No places to bolt or mount a carrier bearing just a drive shaft straight from the trans to the rear end is all I got
Old 07-19-2017, 01:54 PM   #6
61K10
61K10's Avatar
Re: 66 driveshafts
what transmission do you have?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 07-19-2017, 02:57 PM   #7
lswonmatt
Re: 66 driveshafts
3 speed , stamped ( GM 11 ) ( 3830210 ) looks like ( H4 5) stamped below can't tell if there's an x or something stamped after the 5 or the casting is worn down but that's all the numbers i see
Old 07-19-2017, 09:18 PM   #8
65chevysub
65chevysub's Avatar
Re: 66 driveshafts
Can you post a picture of the one piece shaft? I had one made several years ago, but it caused more vibration than it was worth, so I went back to my 2 piece.
65chevysub is offline   Reply With Quote
Old 07-19-2017, 10:11 PM   #9
lswonmatt
Re: 66 driveshafts
I don't have one on my phone at the moment but I will get one and post it but now that you say that I do have alot of vibration when taking off in first or reverse or under a load going up a hill from a dead stop but goes away after taking off or picking up speed I figured it was the clutch going bad and not enough power from the engine dying down
Old 07-19-2017, 10:56 PM   #10
65chevysub
65chevysub's Avatar
Re: 66 driveshafts
I think my vibration was from a bad balance job on the shaft.
Thanks for getting a picture.
Old 07-20-2017, 09:24 AM   #11
lswonmatt
Re: 66 driveshafts
it looks like the cross member is set up for trailing arms even though i have leaf springs but here are the photos as promised
(Photos below in another post photobucket pics wouldn't show up )
Old 07-20-2017, 10:07 AM   #12
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 66 driveshafts
Your posts pics have been photo-bucketed.
Old 07-20-2017, 10:26 AM   #13
lswonmatt
Re: 66 driveshafts
put them in attachments maybe that will work and someone will be able to at least see something
Old 07-20-2017, 10:35 AM   #14
Keith Seymore
Keith Seymore's Avatar
Re: 66 driveshafts
It has to do with propshaft (aka "driveshaft") critical speed.
Propshaft critical speed not just based on wheelbase but is also based on trans type (length), rear axle ratio, tire size, and engine type (larger engines allowing a higher top speed) AND/OR any strange resonances in that particular combination (camping out on that resonance will break the trans/transfer case tailshaft housing).
One other comment - critical speed is not directly related to balance, but rigidity. When the shaft exceeds it's critical speed it begins to bow in the middle and swing like a jump rope. Hence the disturbance and durability concerns.
You can get around it by going to a larger diameter steel tube - or more expensive alternative materials like aluminum, carbon fiber, an aluminum/carbon wrap, or exotic materials like "metal matrix" (aluminum impregnated with other metals) - or - the cheap way out is to limit the vehicle top speed via ignition or fuel cut off above a certain engine rpm.
So - given two otherwise identical appearing trucks - there could be a tire difference that put it over the edge, or perhaps a different horsepower rating which would allow for a higher top speed, or some unseen bending resonance that shows itself during testing which would drive the truck to get a one piece shaft vs a two piece. A long wheelbase truck with a low (numerical) rear axle ratio spins the shaft slower and might get a one piece, but an otherwise comparable truck with a high rear axle ratio might get a two piece.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 07-29-2017, 08:14 PM   #15
lswonmatt
Re: 66 driveshafts
So with the holes in this cross member could it be used for trailing arms if I had the arms the mounting brackets and a pan hard bar?
Old 07-30-2017, 12:02 AM   #16
Captainfab
60-66 Nut
Re: 66 driveshafts
Yes.......
Old 07-31-2017, 12:10 PM   #17
rideblue00
rideblue00's Avatar
Re: 66 driveshafts
1 pc a GMC thing?
rideblue00 is offline   Reply With Quote
Old 07-31-2017, 10:53 PM   #18
Captainfab
60-66 Nut
Re: 66 driveshafts
Not exclusively.
Originally Posted by rideblue00 View Post
1 pc a GMC thing?
